OctaneRender™ Standalone 1.12
pixelrush
>only in the new daylight system
ah! that was it. Wow! spectacular alien scenes.... :arrow: 8-)
perhaps the new model should be the default now.
overall impression of 1.12 is very good
thanks guys. well done.
don't mean to find fault with your good works all the time. ;)
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
smicha
Great work Team. Thanks.
Marcus,
Priority - I didn't see your post about a need to go to preferences and enable priority on my gpu (in cuda devices). Once I found it it works but please add this info to the list of changes. On my TITAN high, medium, low priority allows to use 98%, 96%, 64% gpu usage respectively (msi afterburner). I think that 80% for medium would be more about in the middle of hgh and low. If this 96% is intended this is fine.
Wouldn't it be easier (possible) to turn on/off priority in this pull down icon. Apart from high, medium, low settings just another one - turn on/off priority? Or let a user decide how much gpu usage will Octane use - add an extra dialog box for inputting a value, eg. 100%=turn priority off, 98% high, etc.
I was trying to set background image (an icon next to render daylight simulation) but nothing happens. What am I doing wrong?
Is there a way to go back to default sky colors in New 1 settings?
PolderAnimation
Render priority is a very nice feature! thanks
Win 11 | RTX 5090 | AMD Ryzen 9 9950X| 192GB
abstrax
smicha wrote:Great work Team. Thanks.
Marcus,
I can try to reduce the "priority" a bit further for "medium".
High priority means no priority control, i.e. priority off. The way how priority works is a bit hackish, since there is no way to specify priority anywhere in driver/CUDA land. We actively make Octane wait and reduce the work chunk size and CUDA doesn't allow just any work sizes.
You have to tick the enable checkbox in the dialog and then click "Apply".
I think, removing the RGB spectrum nodes should do the trick.
smicha
abstrax wrote: You have to tick the enable checkbox in the dialog and then click "Apply".
:) I enabled it - still nothing.
abstrax
You selected an image file and still see the checkerboard? What does the log windows say?
smicha
Sorry Marcus,
I forgot to set alpha channel. It works fine.
steveps3
The background image option seems to be very hit and miss. It seems to work ok when your background is a small image but anything large and it just goes a bit nuts.
This is supposed to have a grassy field in the background.
(OS) Windows 7(64)
abstrax
steveps3 wrote:The background image option seems to be very hit and miss. It seems to work ok when your background is a small image but anything large and it just goes a bit nuts.
I guess you can't allocate a large enough texture in OpenGL. Have a look at the log window. If it says something that the OpenGL background texture/buffer couldn't be allocated, than that's the issue. If it is, try switching to the software viewport (in the preferences) or use a smaller image.
steveps3
Ah, ok, if I set the image and then untick "Use Background Image" then click apply and the retick "Use Background Image" and apply again it seems to work.
(OS) Windows 7(64)
