**** TODO LIST / Wishes for Integrated plugin *****
Improdu
Hi Aoktar,
First, thanks a lot for your great work.
My wishes :
1- Compositing tag (exclude objects from reflection, refraction, transparence etc); I guess it also depends to Octane's SDK, but this feature would give much more flexibility.
2- Render priority option (I know the feature is already present but don't work for me); Currently i can't do anything while rendering (despite a titan card).
3- Sometimes the material preview don't refresh, so it's not easy to identify materials.
Thanks and keep up the good work.
indexofrefraction
my 5 cents:
- support for c4d layer shaders, all c4d shaders possible (noise, tiles, ... etc)
either in octane specific texture channel (as described below) or direct support (translate a c4d channel to octane imageTexture internally)
- standard c4d channel input in octane imageTexture (and other octane specific channels)
(support of psd textures with layer selection in c4d channel input or layer shaders for example)
- better conversion of c4d/vray materials to octane
- naming of converted materials without prefix
- use of standard c4d material preview scenes, or at least serveral sdk built in preview scenes
- in the different materials types show only the channels that can be used (less confusing)
(not sure if implementing the node system works. this is too far away from c4d probably.
for me its more important to be able to use all the different shaders that c4d supports.)
- global texture and per material downscaling option (max texture size) to save gpu memory
(means texture sent to gpu is a smaller version of the saved texture. for large evermotion textures for example)
- mac version mac version mac version .)
- more detailed manual, some practical howto tutorials
Mac Pro (2012) 2x6 Core | 24GB | 1 x Geforce GTX580/3GB
NVN
plz a Post-Button in the pictureviewer like Indigorenderer.
BlackX
C4D R14
Setting Time in "OctaneDayLight" does nothing i can not set the Daytime.
When I try to Save Octane scene C4D Crashes.
http://pastebin.com/4uZ5jXxP
BlackX wrote:C4D R14
can you put your file other place? I sended a scene to show sunlight animation.
sun-change.zip
(120.17 KiB) Downloaded 296 times
Jaybee
aoktar wrote:
Jaybee wrote:Having used the C4D plugin for a couple of weeks my immediate needs are:
1) Material previews! I can't properly organise a library of new Octane mats without it.
2) Support for the C4D Region-Render (would save lots of time being able to correct or tweak a small region of the render only)!
Loving the development so far. Thanks again.
Material previews for Content Browser?
Yep, that would be good. The pack you just released (octane.rar) all show material previews in the content browser perfectly here in R13 - thanks!
Win 7 x64 | 1 x EVGA GTX680 Classified & 1 x Quadro FX1800 (display) | i7 920 o/c 3.04Ghz | P6TD Deluxe | 24GB | AX860 PSU
nehale
aoktar wrote:
This is new tested feature:
A screen shot about converting unsupported textures as a image (on the fly)
How do i implement this is the new versions?
Nehale
Windows 10 x64 | 2x GTX680 | i7 990X | 24GB
Cinema 4D R17 Studio + 3Ds Max 2017
OctaneRender™ for Cinema 4D 3.01 + OctaneRender® for 3ds max® v3.14
kristoph
Maybe a 'reset' button for each settings panel?
Mac Pro 5,1 Hexcore 3.33Mhz / Dual GTX 680 / 24GB Ram
C4D R14 / Octane 0.73 / SDK 1.2
