OctaneRender™ for Cinema 4D released
miohn wrote:Hi aoktar,
still I'm not sure whats the right way to deal with textures:
Should I always use f.e. in diffuse:
Texture - C4doctane - ImageTexture - and from there - load a bitmap?
Or can I load a bitmap directly?
Also will be there a possibility to use "filter" ?
And Octane and C4D crashes when closing C4D "API-Error"
(Luckely only when closing C4D and not during work)
regards
Mike
most prefered is octane image texture or standart bitmap with octanematerial.
Filter don't works. You can only octane texture nodes
ashurao
regards
Mike
Filters don't works! OK. This is already an answer to my problem of texture. Instead of going through photoshop, I use a lot the filter in C4D.
Mac Pro 2010 6 cores 3,33 - Mac OS 10.11.6 - 16Go - GTX 780 3Go and GT 640 4Go - Archicad 19 - Cinema 4D R17 Visualise - Octane Render V3
goumz
Ahmet,
It seems when you create a new specular material in 0.3.4 the settings are not actually set correctly for it to be transparent. Transmission float is set to 0 by default, should be set to 1. Just a heads up.
Windows 8 Pro | Intel i7 3770K 3.5Ghz | 32 GB ram | 4 x nVidia Titans
Windows 7 Pro | Intel i7 3930K 3.2Ghz | 32 GB ram | 2 x nVidia GTX 680 4gb
goumz
Actually, there seems to be a LOT wrong with specular materials.... almost everything I'm trying doesn't affect the material in viewport. Roughness, Bump, Index, etc... all update in material preview but show nothing in viewport.
Edit: Older specular materials that I've made in past versions work fine if I copy/paste them into the new scene, seems to be just newly created spec materials from 0.3.4.
IMPICHMENT
Beta 0.3.4 :(
Cinema4D R14.|Octane Stand | Octane for C4D next Corona render
Win8 [64]. I7 3930K . GTX580
IMPICHMENT wrote:Beta 0.3.4 :(
did you restart? Account system tweaked
Edit: Are you sure that's last version. Beta 0.3.4 menus and icons has new stuff.
miohn
the biggest problem for me (also with new version 34) is the disappearing/loosing of texture bitmaps.
I create one texture with a octane image texture in diffuse channel.
As soon as I create a second texture with a bitmap and apply it to another
object, the first texture looses its bitmap.
Is there a workaround for this at the moment?
thanks
Mike
miohn wrote:Hi,
thanks
Mike
can you show me capture of material and object assignment? Seems to point a wrong usage
miohn
Hi aoktar,
here are some screens.
In this case I first added a plane and a diffuse mat with a road-bitmap (tex_1).
Second I added a sphere (converted) with a wood texture in the imagetexture channel (tex_2).
Third I added a C4D sun and a OctaneLight tag.
Now the ground texture disappeared (tex_4)
I'm going crazy because of this!
Does others have this problem too?
thanks
Mike
for last picture, there is only a object in Object Manager. where is ball and sun? Also OctaneLight Tag is works arealights only. For sun you have to put DayLight Tag.
there is templates of usage:
http://render.otoy.com/manuals/Cinema4D/?page_id=233
