DL AO problem with almost black ceilings
giacob
Hi Guys i am a newby with this renderer
I noticed that ao is faster but i get very dark, sometimes even black ceilings....
maybe i make some mistakes in setting ao
can anyone help me?
win8-64bits-g6702gb
Refracty
you can adjust the AO distance.
giacob
it seems to me that if i uncheck new daylight system checkbox the problem disappear
maybe is there a bug with the new daylight system and lw plugin ?
ROUBAL
Check that you have not enabled Smooth for your ceiling ! Smooth applied to flat surfaces usually give black artifacts.
giacob
no i have non smooth on the ceilings surface
the problem come if i enable the new daylight system box in lw plugin
it depends to the version of octane, the newest one 1.11 has a white bottom emisphere, some older version have a dark bottom emisphere that gives the dark ceiling effect ;)
ciao beppe
giacob
when this new version will be released... i dont thimk is out :mrgreen:
ROUBAL
In the Daylight system, try to switch between New and Old model. it is the lowest input of the Daylight node, in the node inspector parameters.
PAQUITO
I would try to lower the AO distance.
AMD FX8350 8 cores. 16GBs RAM
GTX690
Win8 64.
marchermitte
Suffering the same problem here with the 1.11 version and the new sky model. No smoothing applied, black goes away if I switch to diffuse lighting kernel (but much longer of course)
Marc Hermitte
Intel I7 4.5 Ghz, 24 gig ram, 2x Nvidia GTX 480, win 764bits
