OctaneRender® for 3ds max® v1.11c[Test] UPDATED(14March)
User avatar (Default)
merid888
thank you profbetis i can do fog, but exist a problem, dark sides and a strange image, any idea ?
profbetis
Merid, try to make your fog volume fill up as much of the room as possible, otherwise it's like having a big block of fog in the middle of your room which isn't realistic. This is also what's causing the weird lighting issues you're asking about.
Also make sure your depths are high enough (on direct lighting: specular depth; on pathtracing/pmc: maxdepth), they should be around 8-12
GTX 1080Ti 11GB (3x), Water-cooled
Intel i7-5820K 6-core @ 3.3GHz
Windows 10 Pro 64-bit, 32GB RAM
Vanya
merid888 wrote:thank you profbetis i can do fog, but exist a problem, dark sides and a strange image, any idea ?
man make a sphere ;)
Fog by Karba.rar
(135.28 KiB) Downloaded 242 times
Core i5 76o @ 2.8o GHz | ZOTAC gtx58o AMP 1536Mb | MSI gtx46o 1o24Mb | Corsair ForceGT SSD12o | Gskill 16Gb RAM 16ooMHz
be_fast
Oh I would be so happy to get motion blur. Real Smart motion blur (fusion plugin) is fantastic thing but it does not making sence when you use very very high speed moving objects as I do. Pleeeeease
asus p8b ws [email protected] RAM-16gb and 3xGTX580 3gb I love octane and you guyz doing amazing job for us, THANK YOU
merid888
thank you vanya i'll watch the scene shared by you
regards
merid888
hi vanya, es the same error, sphere or not appear dark cornes attach scene and image
1.rar
(264.13 KiB) Downloaded 207 times
Vanya
merid888 wrote:hi vanya, es the same error, sphere or not appear dark cornes attach scene and image
sorry its not opened. obj pleace.
I think in your scene objects are touching eachother, and turns on the black "hole"
profbetis
also you have to make sure the sphere around the camera has inverted normals (usually they point outwards, make them point inwards) and have the same fog material as the volume that it's inside
merid888
add new zip file 3ds max 2012
hi porfbetis i been done all cooment and the result is again, dark corners
1_2012.rar
(263.32 KiB) Downloaded 231 times
Karba
merid888 wrote:add new zip file 3ds max 2012
Fog doesn't work with Direct Light kernel well.
Return to “Autodesk 3Ds Max”
