OctaneRender™ Standalone 1.11
RealityFox
Awesome! May I ask what version you plan on expanding the UV editing tools? I'm really looking forward to them :3
cfrank78
You and many many others :-). We beged in many threads and very often for it, but no one took care of it so far hehe!
Chris!
clausgs
Hi Octane
I see on a earlier topic that there was some problems with V1.11t, I think it was for poser, do this standalone v1.11 have any similar problems or other issues??
I am on the way to download and install the standalone v1.11 update, just want to check with you before i do something that could harm my current setup....???
Claus
Intel Core i7-3770K, 32GB RAM, NVIDIA GeForce GTX 680, WIN 7 64bit.
BorisGoreta
TITAN is giving different render result then GTX690/GTC680 combo.
Second image is TITAN with speckles. How is that possible ? Surface is diffuse with scattering medium.
LudovicRouy
:lol: It's the new feature called "chickenpox" you need a very powerfull CG to render it :lol:
steveps3
Ooooh, I want chickenpox... second thoughts maybe not.
(OS) Windows 7(64)
DayVids
I tried to install it on my macbook pro with GTX 650M, and I get the following error:
Process: octane [7553]
Path: /Volumes/VOLUME/OctaneRender 1.11.app/Contents/MacOS/octane
Identifier: com.otoy.octanerender
Version: 1.00 (1.00)
Code Type: X86-64 (Native)
Parent Process: launchd [134]
User ID: 501
Date/Time: 2013-03-15 21:47:34.033 -0500
OS Version: Mac OS X 10.8.2 (12C3103)
Report Version: 10
Interval Since Last Report: 261069 sec
Crashes Since Last Report: 4
Per-App Crashes Since Last Report: 1
Anonymous UUID: 93105964-5285-C22F-DD82-45629A737C80
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: /usr/local/cuda/lib/libcuda.dylib
Referenced from: /Volumes/VOLUME/OctaneRender 1.11.app/Contents/MacOS/octane
Reason: image not found
CPU - i7-950 3.06 Ghz, 24GB Ram, Win7 x64, 2 display monitors, GeForce GTX 580 3GB Classified. I'm glad to say I LOVE OCTANE!
abstrax
BorisGoreta wrote:TITAN is giving different render result then GTX690/GTC680 combo.
Can you render the scene with only the 680 (i.e. 1 GPU)? If it renders without speckles I would assume that your hardware has sometimes some calculation errors. But to be 100% sure, could you send us the scene and we give it a shot at the office.
Cheers,
Marcus
BorisGoreta
I know what was the problem, I was testing the image rendered with one TITAN versus the image rendered with the rest of the GPUs ( 2 GTX690 and 1 GTX680 ). So with many GPUs the speckles get averaged out because each GPU produces speckles at different pixels.
There is a problem with Octane if I have more then 5 GPUs installed. It won't start. I have to run it in software mode then. But if I run GTX690s in SLI then it works.
Also with more then 5 GPUs and non SLI configuration Photoshop does not have GPU acceleration and OpenGL in 3D software does not work well.
Is there a way to increase max GPU number ?
abstrax
BorisGoreta wrote:I know what was the problem, I was testing the image rendered with one TITAN versus the image rendered with the rest of the GPUs ( 2 GTX690 and 1 GTX680 ). So with many GPUs the speckles get averaged out because each GPU produces speckles at different pixels.
With single-GPU setups or if you want to save HDR images, you may want to the hotpixel filter, maybe 70-80% that should get rid of most of the fireflies. Also try out the caustic blur (maybe set at 0.1 - 0.01 depending on the scene).
Yes, it seems that the NVIDIA drivers have problems with OpenGL on more than 5 NVIDIA GPUs. I don't know why that is, but that was one of the reasons why we added the software viewport mode.
The only way to get around this problem is to use a non-NVIDIA GPU for display, e.g. an onboard Intel graphics.
Cheers,
Marcus
