shadow catcher is borked ...
xtrm3d
or am i missing something ?
xtrm3d
please disregards,
seem that adding an object emiting light did solve my issue
abstrax
xtrm3d wrote:please disregards,
How did you light the scene? If you used a texture environment you have to enable importance sampling, but then it should work.
xtrm3d
Importance sampling is enabled, yes I am using environment only And nope not working on this scene... Although bringing a ""light object "" work ..
Small issue and I can live with it for now :-)
Have way way bigger issue with the octane for maya... That thing is a joke :-(
xtrm3d
just as a confirmation
importance sampling off
and importance sampling on
as you can see the plan is still visible .. a lot less..but still there :-(
thank you for looking into it
xtrm3d
here doing the ""light trick ""
adding a light emmiting sphere with a intensity ads low as possible to brighten the shadow catcher enough and hide the effect
Karba
xtrm3d wrote:just as a confirmation
Seems octane tries to cast shadows from car head light. Try to switch it off.
xtrm3d
nope.. it's still doing it ..
and even if it was the case.. it would be still very bad.. since i need the headlight on in this case .. ( ok.. do not need . but want :-) )
