Concrete near the lake
Yes the initial render is more punshy. I prefer the first one.
- gabrielefx
very nice!
I don't like so much that rounded rocks in the lower center.
We nee rt gpu displacements.
- enricocerica
- Contact:
Ok, I've replaced the first image with the intermediate version, less contrast but still that deep and dramatic atmosphere
paquito: Well, very simple to combine the images, I render one image with HDR, one with Sunlight and I simply use Gimp with one image per layer and playing with the alpha slider to let the background image overlaping the foreground one until the result is what I expect, I also use the eraser to increase the transparency in some parts. Nothing special as you may guess.
gabrielefx:Yep, displacement would be really welcome
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
- marcio_max
Amazing renders, man!
| Windows 8 Pro x64 | Octane for 3ds Max/Standalone | i7 860 | 12GB RAM | 1x EVGA GTX 670 4GB / 2x EVGA GTX 670 2GB | Cooler Master HAF 932 |
beautiful renders as usual mate !!!
- enricocerica
- Contact:
Just added a new image with some water
I think its looks excellent!
my only criticism is that I think the rock texture has too much contrast in it - I often see renderings where this is the case, I believe its because of a 'double' up' in shadows by having a photo-texture already with shadowing, being shadowed again in rendering when it is used as a bump/displacement map or displaced mesh. IMO.
Cheers,
Jonathan.
Cheers,
Jonathan.
Maya 2013 / W7 64bit / Intel i7 980 / 24GB / Gigabyte gtx 580 3GB + 2*EVGA gtx 680 4gb / MB Gigabyte X58A-UD3R / NZXT Phantom - white/black case
Maya 2013/W7 64bit/Intel i7 3820/16GB/ MB Gigabyte GA-X79-UD3 /4*EVGA gtx 680 4gb/SSD 6Gb.s /CM HAF X case
- enricocerica
- Contact:
Just added two more images ...
jmfowler:Well, the texture I used was quite neutral with few shadows but that's true that sometimes such textures may create weird effect.
great, do you create the water with blender?
- enricocerica
- Contact:
Nothing special for the water, simply a normal map in Octane, no displace.Refracty wrote:great, do you create the water with blender?
