OctaneRender™ Standalone 1.11
Refracty
I also experienced freezing issues when loading LiveDatabasematerials.
roeland
Refracty wrote:I also experienced freezing issues when loading LiveDatabasematerials.
Does Octane crash when loading materials? And does it happen for specific materials?
Roeland
ROUBAL
Hi, I am experimenting with SSS, and I have noticed that when using a mix node to mix a glossy material and a diffuse material with Scattering medium, the render doesn't restart to refresh after modifying a setting in the medium parameters, until you move the amount slider of the mixer. Weird !
User avatar (Default)
merid888
hi abstrax i have a problem, when i change the resolution appear the image like the screen, maybe is a bug ? do this in any size
thank you, hope you can help me, i need close and restar the octanerender standalone again
roeland
ROUBAL wrote:Hi, I am experimenting with SSS, and I have noticed that when using a mix node to mix a glossy material and a diffuse material with Scattering medium, the render doesn't restart to refresh after modifying a setting in the medium parameters, until you move the amount slider of the mixer. Weird !
This may be because the diffuse material doesn't have transmission enabled. In this case the medium node doesn't have effect (no rays can enter the object) and it will be ignored.
Roeland
Refracty
Roeland
yes it crashed while loading a material. I couldn't reproduce the problem, but i will do more tests on the weekend.
UruMike
merid888 wrote:hi abstrax i have a problem, when i change the resolution appear the image like the screen, maybe is a bug ? do this in any size
Merid, this seems to be normal, happens to me too.
When you have a high resolution and you move the image with the sliders right and bottom (not the camera but the image) and then go back to a smaller resolution the image stays where it last was.
Simple solution: There is a small icon bottom left under the viewport, two red circles with two white arrows, 'Center Image' or something like this.
It does exactly this, centers the image in the viewport!
Hope this helps, even if it seems to be in the wrong thread... ;-)
Intel i7 | 32gb | Win7pro-64
2 x Geforce GTX 660 ti/2gb +GTX 650 for display| Driver 310.90
DAZ Studio 4.5 Hexagon 2.5 Octane v1.11
merid888
thank you urumike i'll make test and i'll comment
ROUBAL
Thanks Roeland, I will check that point !
roeland
Roeland
Refracty wrote:yes it crashed while loading a material. I couldn't reproduce the problem, but i will do more tests on the weekend.
There is a bug that causes a crash when loading the material "Rock with Lichen" and possibly some other materials, it will be fixed in the next release.
Roeland
