OctaneRender® for 3ds max® v1.11a[Test]
bicket
Hi karba
I think it's a hard job, but octane for 3dsmax is more and more buggy.
i have a problem with textures in this version.
Textures (image texture and float image texture) are not rendered :(
could you check please
PortFolio
4 x TITAN - Win 7 64 - Octane Rocks
Vanya
Karba wrote:
Vanya wrote:
Vanya wrote:First opened not very happy :(
Yes please!!! as soon as I start to use Dirt map :?
Could you check for licence activation?
checked..
I do render without problems.
but when I turn to Dirt texture, it happens... and ''max crash''
Core i5 76o @ 2.8o GHz | ZOTAC gtx58o AMP 1536Mb | MSI gtx46o 1o24Mb | Corsair ForceGT SSD12o | Gskill 16Gb RAM 16ooMHz
bicket
bicket wrote:Hi karba
Hi Karba
Sorry, it's my fault. Octane doesn't like french caracters (é, è, à ...)
PortFolio
mbetke
Yes same with "Ü, Ö, Ä, ß" in german. You have to avoid this stuff in your naming. ;)
PURE3D Visualisierungen
jan kudelasek
same problem like Vanya.
Jan
W7 / Quad Core Xeon E5405 / 24G / Asus ENGTX 480, 580 / http://www.allcity.cz / https://www.facebook.com/pages/Allcity/ ... e=bookmark
gabrielefx
@Karba
thank you
another request:
I noticed you have disabled stereo camera with spherical fov. Is it possible to enable it?
I did two separated spherical renders, I paired them in stereophotomaker....and it works.
p.s.
in Max 2012 the low priority column is out of the passepartout: I read "priorit"
darkline
Thanks Karba, much more stable than the last version.
I am still however getting a small problem with 'movable proxy' objects. When it is active the octane viewport takes over 1 min to load. when octane proxy is not ticked the viewport appears in under 15 seconds.
This seems to do with the complexity of the object. For example, this particular one is a group consisting of 5000 objects. Is it normal that setting a movable proxy increases the processing time by so much?
Windows 7 64bit/ Intel 3930K/ ASUS Rampage IV/ GTX980ti x 2/ 64GB system RAM
cfrank78
Something is really strange with movable proxy option in this release. I rigged a car and all wheels, break discs and tires are linked. All objects i am done with rigging and linking i atomatically make invisible, so i allways know what parts are done and which not. The showing and hiding of movable proxie parts takes sometimes very long and sometimes they do not hide or show, even when i click the reload button in the render viewport! Only solution. Save szene, restart max and contiunue working! Tryied with the same szene in 1.00 - there it works without problems!
Chris!
cfrank78
Does anybody know if teh flickering in the animation stopped? I have no time at the moment to do render tests?
gabrielefx
send your scenes to Karba
with our help Octane will be perfect.
Return to “Autodesk 3Ds Max”
