OctaneRender® for 3ds max® v1.11a[Test]
Karba
BUG FIXES SINCE LAST RELEASE:
  • Incorrect samples amount for animation
  • Wrong material assignment for instances
  • gpu priority settings are not saved properly
This version requires video driver 301.42 or higher.
Limitations on old cards
The PMC kernel and the matte material options don't work on old graphics cards (GTX 2xx, compute model < 2.0).
DOWNLOAD
We have 4 separate archives available for download, for Autodesk® 3ds max® 2010, 2011, 2012 and 2013.
Each archive contains the manual and installation text file, and both 32bit and x64 versions of the plugin,
so you only need to download one archive for your 3ds max® version from the following download links:
3ds max® 2010: http://www.refractivesoftware.com/plugi ... v1.11a.zip (50MB ZIP File)
3ds max® 2011: http://www.refractivesoftware.com/plugi ... v1.11a.zip (50MB ZIP File)
3ds max® 2012: http://www.refractivesoftware.com/plugi ... v1.11a.zip (50MB ZIP File)
3ds max® 2013: http://www.refractivesoftware.com/plugi ... v1.11a.zip (50MB ZIP File)
Yours,
The OctaneRender® Team.
tonycho
Thanks for bug fixes Karba ;)
http://www.antoni3D.com
Win 7 64 |GTX 680 4 Gb (Display) | 3 x GTX690 4Gb | Intel i5 |Corsair 16GB
Elvissuperstar007
many thanks!
Vanya
First opened not very happy :(
Yes please!!! as soon as I start to use Dirt map :?
Core i5 76o @ 2.8o GHz | ZOTAC gtx58o AMP 1536Mb | MSI gtx46o 1o24Mb | Corsair ForceGT SSD12o | Gskill 16Gb RAM 16ooMHz
Elvissuperstar007
Vanya wrote:First opened not very happy :(
dirt work
NVIDIA 580+460
mbetke
I have this error once a day with lots of recent versions. Just close and re-open 3dmax again. YOur render may start but you could get "render failed" from time to time with a cryptic "device error" message in the report window.
PURE3D Visualisierungen
Vanya
viewport is not open. max failure
gabrielefx
@Karba
spherical and cilindrical camera option is good but the viewport feedback is useless, at 360-180 degrees we don't see anything in the viewport.
For me you should adopt an helper that works only in the Octane viewport or add an option to switch on-off Max viewport feedback.
Thank you.
Karba
Could you check for licence activation?
Karba
gabrielefx wrote:@Karba
Thank you.
Probably I have to limit fov for 3dsmax viewport
Return to “Autodesk 3Ds Max”
