OctaneRender™ Standalone 1.11
Elvissuperstar007
ROUBAL wrote:I often can't close Octane 1.11 in a clean way with big scenes : the software freezes, and several times the computer too. According to Win7 ressources manager, Octane seems to have difficulties to purge the System RAM memory, as the System RAM usage starts to decrease and stops decreasing around 50% of RAM capacity.
+1 I also have the computer hangs
mouse stupor
PMC really slows down the system
I can not run in parallel Skype and other applications
Сore2Сuad 9450
Nvidia 580 3gb+460 2gb
314.07
Vin7 64x
DDR2 8GB
FooZe
itou31 wrote:great update !
voxelization is very fast, but drop of performance on render on my 2x580GTX (on benchmark ex : 8.24 --> 7.90) test also on my other scene 8.10 --> 7.50). I know that it's a test release !
But I've read that for 6xx GTX, there's and performance increase !
I think that Titan (6xx archi) will also benefit from that !? (I'm waiting mine next week :P )
Which benchmark scene are you using and what (if any) settings have you changed.
Our test here on the benchmark scene here: http://render.otoy.com/forum/viewtopic.php?f=9&t=7144
(And most other scenes i have been testing with) show a speedup from 1.10 (or even 1.00).
What version are you comparing too?
Chris.
FooZe
Hi Guys,
Here is my results for the benchmark scene (http://render.otoy.com/forum/viewtopic.php?f=9&t=7144) for 1.00, 1.10 and 1.11. It would be appreciated if we could get a few people to do this as well to confirm if there is a problem on some setups.
(These scores are with 2x580's).
1.00
PT no Alpha Shadows: 6.89
Direct Lighting: 23.90
PMC no Alpha Shadows: 5.71
1.10
PT no Alpha Shadows: 6.97
Direct Lighting: 25.42
1.11
PT no Alpha Shadows: 7.62
Direct Lighting: 31.50
PMC no Alpha Shadows: 6.90
Chris.
ROUBAL
ROUBAL wrote: I often can't close Octane 1.11 in a clean way with big scenes : the software freezes, and several times the computer too. According to Win7 ressources manager, Octane seems to have difficulties to purge the System RAM memory, as the System RAM usage starts to decrease and stops decreasing around 50% of RAM capacity.
Abstrax wrote : Which GeForce driver are you using and how many GPUs do you have?
Hi Marcus, everything is in my signature : ;)
CPU : intel Quad QX9650 at 3GHz - 8GB of RAM - Windows 7 Pro 64 bits. Display GPU : GeForce GTX 260 (2 Samsung 2443BW-1920x1600 monitors). External GPUs for Octane : two EVGA GTX 580 3GB in a Cubix GPU-Xpander Pro 2. NVidia Driver : 301.42.
itou31
Hi Chris,
yes I use the same benchmark, and same setting (PT and no shadow) for 1.11 I also set caustic to 0 (same as 1.10).
I have also tested with 1.0
Windows 8 x64
drivers 310.70
i7 3930K
64GB RAM
2x580GTX 1.5GB (OC) (840 core and 2100 at mem)
1.00
PT no Alpha Shadows: 8.29
Direct Lighting: 44.35
PMC no Alpha Shadows: 7.12
1.10
PT no Alpha Shadows: 8.26
Direct Lighting: 44.69
PMC no Alpha Shadows: 7.02
1.11
PT no Alpha Shadows: 7.90
Direct Lighting: 49.84
PMC no Alpha Shadows: 7.56
I7-3930K 64Go RAM Win8.1pro , main 3 titans + 780Ti
Xeon 2696V3 64Go RAM Win8.1/win10/win7, 2x 1080Ti + 3x 980Ti + 2x Titan Black
vinz
Great Work !
DirtMap and Spherical Camera are totally AWESOME !!!
:D
i7 8700k / 16Gib / GTX980Ti 6GiB / win10x64 1803 / Blender 2.78a / drivers 416.34 + Octane 4.0 Standalone / OctaneBlender
abstrax
ROUBAL wrote:Hi Marcus, everything is in my signature : ;)
Could you try GeForce driver 310.90 or 314.07. NVIDIA solved a few problems on multi-GPU setups, maybe that helps.
FooZe
itou31 wrote:Hi Chris,
Windows 8 x64
drivers 310.70
i7 3930K
64GB RAM
1.00
1.10
1.11
Thanks for that,
Looks like there are 4 (possibly relevant) things different than my setup, so we could go through them to see what is happening if you would like.
1) You set caustic blur to zero (this doesn't affect the performance during my tests) so not likely the cause.
2) You are running windows 8, i'm on win 7
3) You are running 310.70 drivers, i'm running 314.07
4) Your cards are overclocked.
My bet is that PT in 1.11 just doesn't respond as favorably to overclocking as 1.00 and 1.10.
I will give overclocking a try with mine as best i can and let you know what i find.
It's interesting to note that PT is the only kernel that runs slower for you, and even then, it's performing faster than mine at stock speeds.
Chris.
FooZe
Hi itou31,
I have OC'ed my cards to the same core @ 840/1680 and mem @ 2100,
But i'm not getting the results you are.
Are you sure you have recently download the benchmark scene and haven't played with any max depth or anything like that?
I'm not getting anywhere near 40 for DL unless i drop the specular depth...
Also, even with overclocking, my PT speeds increase from 1.10 to 1.11.
Chris.
Faizol
Hi all,
is X window system still required to use Octane as a render node on Linux?
Fedora 17 | 16 GB RAM | Quadro 4000 | driver = nvidia 304.xx & CUDA 4.0
