Nose reduction workflow in comp for animations
Dave_Yu
Hi, I would like to know what people are doing to reduce fireflies and noise from animations in compositing apps like Nuke or After effects. I would like to keep this workflow in comp so i will not use the tool in Octane.
For animation, I usually don't set the sample rates too high to reduce render times. Although minor noise is fine depending on the type of shots. I can say it's similar to film grain or video noise.
Dave
JuM
Dave_Yu wrote:Hi, I would like to know what people are doing to reduce fireflies and noise from animations in compositing apps like Nuke or After effects. I would like to keep this workflow in comp so i will not use the tool in Octane.
Dave
You need to render in as high as sample rates then use http://www.revisionfx.com/products/denoise/ for after effect. I dont know much about nuke and denoise tools of it. But revisionfx's denoise is very good.
[email protected]
Best denoiser I found is Neat Video: Reduce noise plugin
Windows 10 64bit, Intel i5, 32gb Ram, 2x nvidia 1080ti, Driver: 390.77
mbetke
After effects has an own Denoise effect. I may be a bit slow but if you don't use it very often it will be okay I guess.
PURE3D Visualisierungen
wisemanxxx
in my opinion neat video is the best. because it has noise profile feature and you can select an area which has real noise and plugin will use this area for reducing
suvakas
I use Composite. Comes free with Max. ;)
Suv
Carl S.
suvakas wrote:I use Composite. Comes free with Max. ;)
Suv
Which tool for noise reduction?
suvakas
Don't remember the exact name of the tool, but it's smth like "Remove grain" or "Grain removal".
Does a decent job.
Suv
wisemanxxx
Here is a sample with my workflow Dave_Yu;
Second image is raw render.My animation will be 1280x720 px but I render scene with double size 2560x1440.This scene is very heavy and I have only one gtx 680 4 gb card :) .My goal is 7-8 minutes render times per frame.That is why I render with only 100 max samples and it tooks only 7minutes at 2560x1440 px resolution.
After rendering process I use reduce noise plugin with this double sized image and put a unsharp mask effect for a little sharpness.
And I put this cleared image to main composition which is 1280x720 px. and resize it to composition's size.
First image is result , very clear then raw render and if you want to get this image directly from octane at 1280x720 you should set max samples value to 3500-4000 maybe more.I know there is a bit missing details after this process.But I prefer rendering speed to some details sometimes.Especially in commercial projects.
I hope it helps you.
ready for compositing
very noisy but double size picture
Return to “Autodesk 3Ds Max”
