Maya 2011 does not support adding the attributes to already existing classes of objects in its API. This feature appeared starting from Maya 2012. So, it is the reason the "mesh" and "subdiv" classes of objects do not create this attribute automatically when you create the object.PhillieDFilms wrote:Yes I use Maya 2011 64bit.
You have two opportunities:
- install the newer version of Maya (2012, 2013, or 2013.5)
- add this attribute to needed "mesh" or "subdiv" object manually (if it does not exist - by default the object will be "Global mesh"):
full name: octGeomType
brief name: ogt
values:
0 - Global mesh
1 - Scatter
2 - Movable proxy
