OctaneRender® for Maya® v1.02b beta [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012, 2013 and 2013.5 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 279€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
BUG FIXES SINCE LAST RELEASE:
  • Fixed the bug that crashed the particles render in some cases.
  • The national symbols in image textures paths work OK now.
  • The min value of Aperture in Octane camera is now "0".
  • A few minor fixes...
DOWNLOAD
OctaneRender for Maya v1.02b beta (65.7MB autoinstaller file)
Yours,
The OctaneRender™ Team.
RickToxik
Thanks! My scene renders fine now!
ypolyz
Thanks, JimStar.
doctorpangloss
-1. Scatter works great. What about movable particles? Particle instancer geometry that responds to the timeline. Maybe background translation, where you translate frame t+1 while rendering frame t?
0. Maybe provide a way to interrupt during translation? I.e., hitting escape while the render view is dark blue, just after hitting the IPR button?
1. I can't seem to get matte to work. Could you maybe post a note on its usage? It would be great if the camera's imagePlane were translated and matte worked as magically in IPR as I would hope.
2. I can't get environments to render in IPR after 3.00... any new settings there?
Win7x64 | GTX 580 | Maya 2011
doctorpangloss wrote:1. I can't seem to get matte to work. Could you maybe post a note on its usage? It would be great if the camera's imagePlane were translated and matte worked as magically in IPR as I would hope.
Can you please explain more detailed what you mean?.. Perhaps some screenshots...
arh-osa
Great! Thank you JimStar!
Is there motion blur support in the current version? I can't find these settings.
SketchUp Pro 8/ Maya 2012 / W7 64bit / Intel i7 870 / 8GB / 2*GeForce gtx 680 4GB
arh-osa wrote:Is there motion blur support in the current version?
No.
doctorpangloss
I've also been seeing a lot of "// Error: line 0: Image conversion (to IFF) failed" messages. I think it's from a LiveDB material I'm using, but I can't find which one.
NEWLOGIC
Does anyone have problem with noise when rendering scene using HDR image in Maya 2013?Did you come up with solution?
RickToxik
It's the thing I was talking about in the other thread: the HDR importance sampling.
Jimstar has to write new code for maya each time they add something in the native Octane engine. Otoy has announced this new feature, so it should be available in the maya plugin in one of the upcoming updates.
The HDR importance sampling will work specifically into reducing noise in HDRI renders. Should be a super great new feature!!
Return to “Autodesk Maya”
