This process may be of interest.
It's not perfect, but hey...give it a try , it may work for you
The old firefly problem, caused by point lights aimed at reflective surfaces.
the first image was created to illustrate the problem.
Rendered for only two minutes using one high powered point light through a glass teapot and onto a high gloss floor in the PMC Kernal
The result...as you can see, a hell of a lot of fireflies..
options
1)..continue to let it render for a long,long time till the fireflies disappear....or a somewhat shorter time if you have 6 x GTX670's installed!
or:
2) load it into Photoshop or Elements and
A) Install this plugin
http://www.redpawmedia.com/
look for the hot pixel noise remover plugin on the web site
B) select just the areas in the image in Photoshop where the fireflies occur.
C) Run the plugin , maybe once or maybe a few times till the fireflies disappear
see the before and after images attached:
total processing time.........a hell of a lot shorter than letting the image cook for an hour or two in order to get rid of those damn fireflies.
Please note that the plugin ( which is free by the way) will only work on 8 bit images, not 16 bit, so you will need to convert it to 8 bit if you've saved the file as a 16 bit image.
