OctaneRender™ Standalone v1.05 (obsolete)
roeland
Hi all,
This release contains some fixes for bugs introduced in the previous release.
NOTE: PMC kernel and material option don't work on GPUs with CUDA compute model < 2.0 (for example the old GTX 2xx).
Changes since 1.04:
  • Fixed GPU crash on changing resolution.
  • Fixed rendering artifact on perfectly smooth glossy materials.
  • Fixed reloading a mesh nodes: the node pins and the rendering are updated properly.
  • Improved white point picking.
  • Hotpixel removal works with post processing.
  • Fixed some small issues with resolution lock.
  • Added spectral effects to post-processing node.
Downloading:
Windows:
ZIP archives:
- 64-bit32-bit
MacOS X:
DMG image:
- 32-bit and 64-bit
Linux:
tar.gz archive:
- 64-bit
Roeland
Reason: added missing item to change list
pixelrush
Hmmmm OK ... I haven't actually used 1.04 yet.. :)
Thanks for the quick fixes though ;)
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
abstrax
pixelrush wrote:Hmmmm OK ... I haven't actually used 1.04 yet.. :)
We just want to get to stable 1.10 as soon as possible, so that we can then release the new stuff piling up in the repository... ;)
pixelrush
Well I wouldn't want to hold progress up then.
I'll just have to be faster to download them won't I ?
Octane v1.55
pixelrush
To be honest its a while since I gave Octane a good work out.
After 5-10 mins I got a fail trying to pick a focal point. see attach - not sure if its easily repeatible
Also why cant I get a decent metallic appearance by running up the specular in the screws scene now?
Octane v1.55
abstrax
pixelrush wrote:To be honest its a while since I gave Octane a good work out.
What failed was the PMC kernel. Please lets us know if you have a way to reproduce the problem.
Regarding the metallic appearance: What is the setting of the index pin of the glossy material?
Cheers,
Marcus
pixelrush
...index pin... :oops: :roll: sorry ;)
still trying to reproduce the other :x
Octane v1.55
Jaberwocky
Thanks Roeland
Going to see if i can break it........... :twisted:
thanks for the new version, all works perfectly for now ;)
the spectral effect it's really cool :D
ciao beppe
Refracty
Hi Marcus,
I am looking forward for the good stuff coming in. The new features will make a big step forward for development of octane.
Good progress.
One question about object motion blur.
Is this hard to implement for the near future?
