Here's the newest version of the exporter tool.
the OBJ file size and processing time is optimized somewhat etc. The (c) is also updated to 2013 etc.
Install by extracting the contents of the ZIP into your Plugins folder, maintaining all helper files within their subfolders as inside the ZIP, when appropriate.
Restart Sketchup to auto-load it.
Read the instructions provided...
Octane Sketchup Exporter 1_00-01
- Octane_1_00-01.zip
- (450.25 KiB) Downloaded 336 times
TIG
- Jaberwocky
Cheers Tig
thanks for the update.
Installing it now
Installing it now
Thnx TIG,
appreciate it.
greetz,
appreciate it.
greetz,
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
Thanks TIG.
Do you code all of the updates available at
http://sketchucation.com/forums/viewtop ... 23&t=33448
into Octane Sketchup Exporter?
I didn't include the vertex-reuse code in the current Octane version because at the time it was noticeably slower and it was only needed for some specific OBJ uses anyway, and there was no benefit in an OCS situation, and including another dialog asking if you wanted to 'compact' the vertex-data seems inappropriate...smicha wrote:Thanks TIG.
However, since then I have optimized the general-exporter's code and it now runs a few % faster with the newly coded vertex-reuse... so the option isn't needed now.
When I get a moment it will update the Octane code using these new algorithms - it should make most OBJ file creation slightly faster and the smaller file size should also speed up loading into the OCS...
Watch for updates...
TIG
Thank you TIG.
