OctaneRender™ Standalone v1.04 (obsolete)
roeland
Hi all,
This release contains mainly bug fixes and small improvements towards a stable 1.1.
Changes since 1.03:
  • Added white point picker.
  • Fix swapped stereo filter colors.
  • Tweaks to the new daylight model.
  • Reduce delays when switching render targets with environment importance sampling enabled.
  • Fix default color of materials.
  • Center viewport button doesn't reset the zoom.
  • Added menu item to node inspector and outliner to show a node in the graph editor.
  • If Octane can't load a node in an OCS file it will still load the rest of the OCS file rather than canceling the load.
  • Fix crash on selecting the project root node in the outliner and pressing delete.
  • Fix crash on selecting show in outliner if no outliner is displayed.
  • Add --no-opengl command line switch to start Octane if OpenGL doesn't work.
Downloading:
Windows:
ZIP archives:
- 64-bit32-bit
MacOS X:
DMG image:
- 32-bit and 64-bit
Linux:
tar.gz archive:
- 64-bit
Roeland
ROUBAL
Thank a lot ! I will try that asap ! :)
Elvissuperstar007
bug
Change the resolution 1024h512 to 1024x768
310.90 NVIDIA
abstrax
Elvissuperstar007 wrote:bug
310.90 NVIDIA
Does anyone else have similar problems? Elvis, what does the log say (Help -> Open Log...)?
Marcus
Jaberwocky
Abstrax
Yep, it happened to me.
Switched to custom resolution and input 1024 x 768
see attached.
Also noted that the interface is very sluggish now for those of use using a single GPU for display and rendering.
rappet
Yes, happened to me too,
greetz,
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
Force44
and me
log:
Started logging on 30.01.13 16:30:41
CUDA error 999 on device 2: An unknown internal error occurred.
-> Kernel execution failed (pick)
CUDA device 2: Picking failed
CUDA error 999 on device 0: An unknown internal error occurred.
CUDA device 0: Picking failed
CUDA error 999 on device 3: An unknown internal error occurred.
CUDA device 3: Picking failed
CUDA error 999 on device 1: An unknown internal error occurred.
CUDA device 1: Picking failed
screen
http://www.picfad.com
Core i7 2600k @4.2 Ghz | Asus Maxiumus V Extream | 3 x GTX 590 watercooled| Crucial Ballistic Sport 32gb | Crucial m4 64gb | Seasonic Gold 1250 | Octane render| Skethcup Pro 2013 | Blender 2.68
funk
Thanks for the update!
Please take note though guys:
PMC no longer works on GTX285
This got broken in 1.03
abstrax
funk wrote:Thanks for the update!
Yes, it's a compiler problem. We couldn't find a workaround so it probably will stay broken unless future changes make the CUDA compiler cooperate again. We spent several days on it, but couldn't solve it and since most of our users are using Fermi and Kepler cards it doesn't make sense to hold back development only because we have reached the maximum complexity, the old CUDA compiler can deal with.
Cheers,
Marcus
abstrax
310.90 NVIDIA
Ok, thanks. It's the autofocus picking that falls apart. Thanks for the report.
Cheers,
Marcus
