room with pillows
PAQUITO
Here´s my second scene. AO as usual.
AMD FX8350 8 cores. 16GBs RAM
GTX690
Win8 64.
tonycho
Wow Paquito
you are master of AO Rendering :lol:
looks Great
http://www.antoni3D.com
Win 7 64 |GTX 680 4 Gb (Display) | 3 x GTX690 4Gb | Intel i5 |Corsair 16GB
PAQUITO
Thanks man, there are some issues with the mapping that should be fixed. I will try to redo it.
GTX690
Win8 64.
paoloverona
cool render paquito,
maybe you should have put little more accuracy with the modelling of the blanket and some pillow too, they look too much "rigid".
...I really love the brick wall.
intel i7 3820 3.6GHz, 16Gb 1600Hz, windows 7 professional 64bit, gtx 580 3Gb x2, Octane 3dsMax 2.58
PAQUITO
Yes paolo, that kind of stuff is not modeled, but calculated through a cloth simulation. I need to learn more how to properly calculate a soft body, I can make it look good with clothes, but not with closed soft bodies, such as pillows and stuff... Still learning :P
GTX690
Win8 64.
sampakinpa
Great work!
Do you use post effects and color correction, gamma etc. from inside octane? If yes, in what way?
2x Xeon E5-2620, 32 GB RAM, 4X GTX1080ti, Windows 10, Octane 3 for Maya 2018, Radeon HD6450 for disply BRIO Animation ltd
PAQUITO
I dont use post production from octane, its always Photoshop, it gives me more fluid and extended control over the image.
GTX690
Win8 64.
sampakinpa
Using layers? or directly on the final render?
PAQUITO
Always using adjustments layer, so I can tweak it if needed without destroying the image.
GTX690
Win8 64.
PAQUITO
Ok, so after some research I finally found how to make a nice pillow deformation. Here is the result: same scene with better deformation and mapping:
GTX690
Win8 64.
