OctaneRender™ Standalone v1.03 (obsolete)
abstrax
MattRM wrote:Hi all,
Great upgrade on interactive work !!!
Still the stereoscopic bug, left cam/filter is the right and right cam/filter is the left, it's inverted.
Matt
We didn't have time to look into that one yet. The bug report came too late. If it's a bug, we will fix it with the next version. Should be trivial.
MattRM
Matt
Don't worry it's just to report the bug ;)
Do you have an idea when the volumetrics will be put in the build ?
Matt
kavorka
abstrax wrote:
kavorka wrote:Another thing I have noticed, and I think it is just with this version, is after I load my scene, it still shows a loading bar on the bottom, even though it already loaded that particular item. Once it was my HDRI and it just happened with my .obj.
clicking cancel doesnt do anything. It doesnt seem to cause any problems though, both actually loaded and I use use Octane as I normally would.
On which OS are you working?
I'm on windows 7 64.
My home comp only has one GPU, ill try and send you a log early in the week from work.
abstrax
Matt
The "volumetrics" are part of the work for architectural glass, which will be released after we have reached stable 1.10 (with the current feature set). 1.10 is hopefully only days away. There is still some work to be done on architectural glass and some other development currently in progress needs to be finished first, but then it will be released.
Cheers,
Marcus
Great version, the new features are very useful:
-Tweaks to the new daylight model. The bottom half is not black anymore, which improves the appearance of ambient occlusion.
wonderful this is great for AO interiors
-Fixed default diffuse color of glossy materials. Diffuse and glossy materials have 0.7 as default diffuse reflectance.
could it be possible to have a gray colour instead of a pale blue?
-Connecting a post processing node doesn't restart the renderer.
this is so useful, thanks
-The reset image position button also restores 1:1 zoom.
I often work at 50% for checking the noise reduction and this new function is not very comfortable, it would be more useful to have a standard scale box field somewhere in the interface
-The file dialog starts at the location of the current image when loading a new image in a texture node.
useful
-Copying and pasting nodes will also duplicate connections
this is wonderful, i love this one, thanks
ciao beppe
abstrax
bepeg4d wrote:-Fixed default diffuse color of glossy materials. Diffuse and glossy materials have 0.7 as default diffuse reflectance.
It was supposed to be gray, but a bug sneaked in and made it blue ;)
Ok, we will change it back and will add a "1:1" button, when we have some time at hand.
Cheers,
Marcus
gabrielefx
Matt
please support quad buffered stereo output, stereo cam and stereo output for pro user (see vray)
MattRM
Matt
Agreed +5
Matt
niuq.cam
With this new v 1.03
Saving a scene is now instantaneous.
Moving one of my 400 nodes in the window is instantaneous too. (before it was minutes at each displacement...)
Perfect ! :D
kavorka
every scene I load with 1.03 (I export from Blender each time) ends up showing an error in the loading area. After everything is loaded, it will still show that it is loading something. Sometimes my mesh, sometimes a texture. Seems to be purely graphical because everything works fine, even what it says is "loading".
I just opened up this same scene with 1.0 (without exporting again from Blender) and the problem persists. I haven't had this problem before 1.3 (that I know of)
