New feature : Shadow Catcher
whersmy
I suppose you mean the diffuse material of the ground, that I want to have transparant? I simply assigned a diffuse material to it, but only the standard settings show up. :| No matte.
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
kavorka
whersmy wrote:I suppose you mean the diffuse material of the ground, that I want to have transparant? I simply assigned a diffuse material to it, but only the standard settings show up. :| No matte.
Are you sure you are using 1.01 or 1.02?
it should be right there on the bottom.
Edit: In your post, it says you are using 1.0. You need 1.01 or 1.02 which was just released.
http://render.otoy.com/forum/viewtopic.php?f=33&t=26121
whersmy
I just downloaded it, came from 2.58e and thought that 1.00 was the latest!
Coooool! Will give it a go, thanks kavorka ;)
kavorka
whersmy wrote:I just downloaded it, came from 2.58e and thought that 1.00 was the latest!
Here is the change log for the 1.01 release, just so you know all the features that have been added :)
http://render.otoy.com/forum/viewtopic.php?f=33&t=26011
whersmy
I purposedly bought 4 x 580s, to reduce the rendertime when using a big hdr. Importance sampling is crazy!! 8-)
nildoe
Hello All,
Is there any solution for the bug regarding the colored shadows on matte materials already?
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
also additional options for invisible to camera or invisible to reflections makes more competative
skater_man
how to use shadow catcher ?
Return to “Works In Progress”
