Multi GPU support questions
Krisonrik
Does the 2nd GPU has to have the same amount of VRAM in order to work properly... I mean in case you are approaching maxing out your 1st card VRAM but the 2nd card has even less VRAM, can the 2nd GPU still be utilized? And I also I thought Radiance mentioned animation along with GPU in the competition thread. Is it true? Are we getting animation in 2.1? :shock:
Dual Lindenhurst single core Xeon 3.6Ghz with Hyperthreads, 8GB DDR-2 ECC, Geforce GTX 260
Dual Xeon 5680 3.2Ghz with Hyperthreads, 24GB DDR-3 ECC, Quadro 4800 & GTX 480
radiance
you need to have the same or more ram on the 2nd GPU.
eg, if you have one card wiht 512MB and one with 1024MB, you can only use up to 512MB, as the whole scene needs to be stored in each GPU separately.
2.1 will offer OBJ based command line flags and a few other animation options,
but not a full RIB/collada based animation pipeline, that's for beta3.
Radiance
Krisonrik
radiance wrote:you need to have the same or more ram on the 2nd GPU.
Radiance
Is that in the neighborhood of moving around camera or move everything up and down kind of thing?
radiance
Radiance
you'l see, it's a suprise feature :)
Radiance
pixelrush
turntable? flyby? :mrgreen: :geek:
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
andrian
Radiance
Radiance
Another surprise.. :shock: :shock: more employees? FBX ? merge VRAM memory between two VGA? Or using PC physical memory? Or instances :O .. now I can't wait....
Vista 64 , 2x Xeon 5440 - 24GB RAM, 1x GTX 260 & I7 3930 water cooled - 32GB RAM, 1 x GTX 480+ 1x8800 GTS 512
CGsociety gallery
My portfolio
My portfolio2 - under construction
Web site
Making of : pool scene - part1
