You won't need full 16 lines per video card to render with octane. x4 is the sufficient number of lines, tested, no render speed loss found.mdharrington wrote:remember it is not just about number of pci express slots....but number of usable lanes
a lot of motherboards will only give you one or 2 lanes running full 16x....
Good motherboard for maximum GPU
Asus P9X79 WS, i7-3930K set to 4250mHz, EVGA gtx 1080 FTW DT 8Gb + Zotac gtx 580 amp2! 3gb
http://www.asus.no/Motherboards/Intel_S ... Z9PED8_WS/
4x 16lanes + 4x 8lanes =) but You need twe E5s =p
- gabrielefx
nice product!glimpse wrote:http://www.asus.no/Motherboards/Intel_Socket_2011/Z9PED8_WS/
same with gigabyte sniper g1 v.3 it still only can put 4 vga there, 1 vga take 2 slot when you put the vga in that motherboard.
rendercamp
virtual photography & 3d animation
asus maximus extreme VI :: i7 3770k :: 16 Gb Ram :: 4 GTX 690 4 Gb :: win7 64 bit
I would advise not to choose this item =) some say (rephrase) ”it's as bad as sr2 was good“smicha wrote:http://www.evga.com/Products/Product.aspx?pn=270-SE-W888-KR
to name few things: some unreasonable layout choises, all lanes conected to one CPU, crapy unfinished Bios etc.
no wish to spoil anything just informing to make a good homework before deciding to go for product like this,
..there are better made products (like the one i've posted before) that actually are priced lower too..
Glimpse,glimpse wrote:I would advise not to choose this item =) some say (rephrase) ”it's as bad as sr2 was good“smicha wrote:http://www.evga.com/Products/Product.aspx?pn=270-SE-W888-KR
Thank you for your remarks. I was considering whether to buy evga vs asus motherboard and now I am more and more convinced that I'll go with asus.
Look for a spacious case!
I had to put PSU outside the case to fit 3 GPUs.
http://www.visnevskis.com
Vista64/Ubuntu, GTX470/580
Also there has to be a powerful PSU. Or two of them.
I wanted to push GPU count to max. I even got adapters to use 1x slots and those close to each other to make it to 7GPUs, but as I got to three I was satisfied with performance enough and gtx580 3gb went out of stock at the same moment, so I decided to stop.
Still, rendering it eats over 800W which with monitor and a smaller computer is enough to make small room hot when it's snowing.
