Or is there an afordable expansion box option.
please note - you will need a riser for the 4th slot as you can't fit a double width card down into the slot properly because there are cables in the way, also meaning you will need to place this card somewhere in your case nearby.pixelrush wrote:Depends how much you want to spend and how badly you want extra cards I suppose.
You will probably need to do a home grown case and install pci-e risers if you are really keen.
I've been looking at a Gigabyte GA-X79-UD3 which can take 4 double slot cards and is quite reasonably priced I think but I'm not going for a max rig. That's a 2011 socket mobo though
You can find similar cards for 2x the money and 7 single slots for 4x the money like the eVGA Classified SR-X.
This sort of question has been asked before so there are a few posts in the forums you could search out.
