Shadow catching and compositing
radiant
G'day guys,
Here is something that i might do in the next tutorial.
Its merging alot of passes and editing them together in photoshop or gimp.
Suzanne is the only thing thats *mine* the image was from a random google search
Here is the final:
Passes
any critics are welcome for technique or other.
Radiant
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
MaTtY631990
Good start ;) . There is small issue which a aliasing problem at the bottom of the model and a bit to much light.
Maybe as well try with a different color or textured material.
Tugpsx
Great job. Your tutorials are very informative and look forward to this one too.
Job well done thanks for sharing your findings.
paoloverona
I was trying to test this new feature "shadow catcher", but one thing that I cannot do is to use a background image in the rendered viewport ( i can only see it in the 3DS Max viewport, but in the render I see it mapped as spherical enviroment).
Is there something that I miss?! :?
Thanks , Paolo
intel i7 3820 3.6GHz, 16Gb 1600Hz, windows 7 professional 64bit, gtx 580 3Gb x2, Octane 3dsMax 2.58
MaTtY631990
I think you are referring to screen environment mapping what other render engines can do. Octane only supports spherical mapping at the moment. Just use the 3dsmax viewport background to fit your model correctly and composite over background in your image editor.
paoloverona
thanks matty...unfortunately I was guessing that :(
Hope that this feature will implemented in a not so far future :D
Cheers, Paolo
Return to “Works In Progress”
