OctaneRender® for Poser beta - build 1.02p [OBSOLETE]
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Poser, build 1.02p (TEST VERSION) - this is the STABLE release plugin code compiled against Octane release 1.02.
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- Poser version (Poser -> Help -> About Poser) - list the build number (eg. 9.0.3.23027)
- Also have ready a copy of the octaneplugin.log and cuda.log file from your Poser temp direction (Poser -> Edit -> General Preferences -> Misc tab to find the temp directory)
Change Log from release 1.00p
- Compiled against Octane release 1.02. That means it has the following additions:
- Post processing effects (see postproc node in the rendertarget tree). Remember to Enable "on_off".
- Environment - Importance sampling added (enabled by default)
- Environment - new daylight model - set model to 1 to activate it
If you have questions....
- Read the manual
- Read the FAQ
- Watch the Features Video
- Read the Features Blog Posting
- Watch the Introductory Tutorial
- Check the Facebook Page
- Post your question on this forum thread
Troubleshooting
- GUI issues (lock-up/crash) on large scenes (ie. 4million polys) - potentially due to the Windows Vista/7 "Timeout Detection and Recovery" http://msdn.microsoft.com/en-us/library ... 87368.aspx. Settings can be changed using Regedit. The recommended setting for Octane are registry setting HKLM\System\CurrentControlSet\Control\GraphicsDrivers, TdrLevel = 3, TdrDelay =10 (if these settings are not already there, rightclick the right panel -> New -> DWORD). You will need to reboot after changing these settings.
Limitations
- Loading a Poser scene by double-clicking a pz3 file in the Windows file explorer, or selecting from your "Recent Files" will not load the previously saved Octane scene data for that file when Poser starts. This is due to a Poser bug which has been reported to Smith Micro. Instead, use the Poser menu File -> Open to open any pz3 files which contain Octane scene data.
- Material Picking (by clicking on a material in the Poser Material Room) does not select that material in the OctaneRender material tab if you have a camera selected in the Parameter Dials window.
- If you delete a duplicated figure in Poser, when next reloading the scene, the figures may have been renamed, in which case the plugin will not have loaded the materials for the rename figure correctly. This has been reported as a big to Smith Micro and will be fixed.
Download the plugin HERE
mlru
Aww, man, how nice!
I'm sooo keen on the Importance sampling - it's such a time saver.
I really like Christmas. :D
Win11/64Bit | GTX 4090 24GB | NVidia Driver 546.29 | Octane 4.05 | DAZ Studio 4.21
The importance sampling is ON by default. The Ortho camera is in there too - it's the "orthographic" setting under "camera".
vipvip
good news, i try it this weekend !
Zay
I added a car to a scene and got a cuda error:
Octane log:
DEBUG:root:Mesh node for Figure created 0x36c77f90L
DEBUG:root:connectMeshToGeometryGroup:UpdateChangeManager
DEBUG:root:connectMeshToGeometryGroup:done
DEBUG:root:created geometrycache for figure Figure pinNum=4
DEBUG:root:Cuda Error : Mesh Parameter Error:
DEBUG:root:Closing settings window - clearing callback
DEBUG:root:Closing settings window - saving window locations
DEBUG:root:Closing settings window - reseting project
DEBUG:root:Closing settings window - destroying window
CUDA log:
Opening OctaneRender for Poser Setup Dialog
Input polygon 165063 has not enough vertices.
Closing OctaneRender for Poser Setup Dialog
Michael314
Instant Christmas! (Glare = 3) ;) ;) ;)
I like it! Thank you very much.
Best regards,
Michael
Win XP 64 | GTX 580 (3 GB) | Core2Quad 2.83GHz (Q9550) | 8GB
Win7 Ultimate 64 | GTX 680 (4 GB) | Core i7 X980 | 24GB
wimvdb
This new version sometimes does not start rendering when you open de viewport. No idea why
Just refreshing the scene makes it start.
This happens also when you start the plugin (which should read the entire scene since it has all the changes), but the viewport render opens and does nothing. Press refresh and then it goes.
If nothing was changed in the plugin this must be caused by the new octane version
No big problem, just something to look at
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
Zay - did the old 1.0p version load the car? I suspect it's due to the car having a polygon with 2 vertices. I'm hoping to code the next plugin to handle this situation. Was the car a prop or figure?
Mmmm, that does sound like the new version of Octane. When the viewport is stalled, does the cuda.log file list any cuda issues?
Zay
1.0p didn't load the car either. 110a did. Was the same car I made 1.000.000 instances off.
http://render.otoy.com/forum/viewtopic. ... 9&start=20
I found 2 other cars that also fail to load. Same error. All cars are figures.
viewtopic.php?f=46&t=25159&start=20
1.00p I added a check of the cuda log. The car is raising a cuda error. The same error would have been being raised on 110a (but being ignored) and manifesting in a lockup further down the track. Also, try exporting the car to a prop - the plugin loads props in a slightly different way, so you /might/ find it loads that way.
If you send me the car, I'll make sure it loads in the next version.
Return to “Poser”
