SHADOWS CATCHER
Interfaces
I can not run the new function Matte,the shadow does not appear in the alpha channel.
it comes from sketchup???
Thanks for yours answers
Interfaces
I forget the file
excuse me
essai.zip
(6.33 KiB) Downloaded 234 times
TIG
The 'post_processing' node file is missing so the OCS won't open... :?
TIG
Interfaces
it works but it is not a shadow, see update file
test.zip
(29.67 KiB) Downloaded 240 times
TIG
You still supplied an OCS with a node that has a missing file !
I remade the OCS etc and got this [including resolution and sun/shadow settings 'from current view']...
What's wrong with it ?
TIG
Interfaces
the diffuse material if you check the matte surface disappears and logically must leave the shade only alpha plane back.
on such matter + shadow remains.
sorry for my english
TIG
I'm afraid I don't understand :?
Post in the original language and I'll try to translate...
TIG
Interfaces
Logiquement d'après ce que j'avais compris sur la matière diffuse sur la nouvelle version d'octane (1.01) on a la possibilité d'avoir en mode alpha channel l'ombre directement juste en cochant "matte". Mais on a la combinaison des 2 (ombre + matière). Quelle est la méthode pour avoir uniquement l'ombre?
Merci.
TIG
Logically from what I understood for the diffuse material, in the new version of octane (1.01), we have the possibility of change alpha channel shadow directly, just by clicking "matte". But there's the combination of the 2 (+ shadow matter). What is the only way to have a shadow?
I don't have 1.01, only 1.0 so perhaps this is the start of the confusion...
Where did you get a newer version ?
It's not an available download ??
What exactly is 'matte' - where in the controls/options etc...
Isn't this really a general v1.01 question, devoid of any connection with Sketchup, because it will apply to every possible OBJ/MTL you try to import into an OCS ?
TIG
Interfaces
The version 1.01 is here :
http://render.otoy.com/forum/viewtopic.php?f=33&t=26011
Added matte setting for materials which makes it transparent if not shadowed:
http://render.otoy.com/forum/viewtopic.php?f=6&t=25747.
Peut- être qu'il faut mettre de l 'opacité sur la texture? je comprends pas très bien!!!
Return to “SketchUp”
