OctaneRender® for Poser beta - build 1.01d [OBSOLETE]
Oh, and a scalable Setup window REALLY would come in handy ;)
It's pretty much at the top of the list of things to do :-)
mlru
face_off wrote:Interesting Uwe. And yes, a very good start. I assume you've seen http://poserphysics.blogspot.com/2012/1 ... hader.html?
Yes, it's a pretty similar approach as I usually use in the stand-alone version (from which I derived my Poser-plugin settings).
face_off wrote:
Direction goes more to +1 because we want the light to travel through and not reflected.
I only did studies with frontal and side lights - not back lights. In those cases, I didn't find any difference between -1, 0 and 1 for direction. However the reflected light should be as important as the back light - so I thought 0 would be the best for the direction.
Well, I politely have to disagree.
My impression is, that in most "usual" light conditions, be it sunshine, overcast or indoor radiance, SSS doesn't play a noteable role. I think SSS only really contributes in special cases like back-lighting, when the translucence of the tissue really becomes notable. If I look now on my skin, or that of the people around me, I really don't notice too much of a SSS.
So, if you have a more undirected scattering, you'll get the effect even under conditions where you wouldn't want it (i.e. resulting in reddish shadows on the skin, 'glowing' skin, wax-like look)
What really gets -back- reflected (esp on very pale parts of the skin) is the color of the subcutaneous tissue and blood vessels, but that has nothing to do with SSS, in my opinion.
I don't have the slightest clue how to implement a subcutane map in Octane :D, no matter the fact that I think this isn't needed. A good diffuse map can do that, too.
face_off wrote:
absorption:0, scattering:0.09
I found with absorption at 0, there can be a buildup of light inside the mesh - which is what is happening in her nose. Again, I'm not expert, but I found you need the absorption near the scatter value so that the light doesn't scatter forever.
That's exactly the function of the SSS-map. Being a floatimage, the brighter areas allowing more and the darker area allowing less or no scattering.
With a SSS-map the absorption value becomes obsolete (or better - HAS to stay 0.0).
I'll fine-tune my settings and test them under different light conditions and will post the results here.
Uwe
Win11/64Bit | GTX 4090 24GB | NVidia Driver 546.29 | Octane 4.05 | DAZ Studio 4.21
vipvip
Ok Paul
i understand your reasons for copy/paste and other things...
Sure you'll find the better way to organise shortcuts ! For the top position for copy/paste,it is a good idea !
for "This already happens - if you go into the Poser Material Room, and select a Poser material, it automatically selects the Octane material in the Material tab. Is that what you meant?"
i just meant that when you select an object, actually, it selects automatically the material concerned ( which is great ! ) but just the level 0 ( see pict. attached), i propose you the same process but develop the 1st level of the material instead of keeping it 'closed': it just avoids to open it ( gain of 1 click ) -> hope you understand, here is a screen capture to illlustrate
Vincent
vipvip
..and when there is only 1 material in the object, the must-have would be to develop directly the material tree, which become the 'level 1' ( picture attached)... if possible of course ;)
I have re-uploaded 1.00p - so if you are already on this version, pls redownload and install it for the following fixes:
- "Select Image File" now picks up all Poser files from all nodes in the Poser Materials (not just texture, bump and trans).
- Adjusted the width of the filenames in the "Select Image File" combo boxes (they are now shorter).
- When "color picking" from the color popup, all ok/cancel/etc buttons are disabled, so <space> or <enter> MUST be used to exit color pick mode
- Fixed issue where loading a pz3 file would sometimes not load the Octane materials that were previously saved
Ah, so would like the Poser prop/Figure selected AND expanded (so you see all the prop/figure materials)? Keep in mind also that as you click more Poser props/figures, it will expand more of the tree making it look a little "messy".
vipvip
that's it
For consecutive selecting, it closes the previous one to expand the last selected... of course, it is (again) just a suggestion...
Thanks Vincent - I can certainly add that feature. Collapsing the previously selected tree may be an inconvenience for some users - however I'll see how it goes.
vipvip
"Collapsing the previously selected tree may be an inconvenience for some users",
yes probably and in some case for me too...
thanks
thanks
Tweaking workflow can be a sensitive area - what works for one user might not for others. So unfortunately I need to take a cautious approach to changes like this :-) I've also got some other changing to do which I think you'll like, but they are a week or two away.
Return to “Poser”
