Hey Karba,
Could you please add a way to render hidden geometry?
It could either be a new checkbox or use standard "Render Hidden Geometry" setting under Common tab.
This would be very useful for rendering out large amounts of instances or for heavy models too. Hiding stuff from view makes viewports a lot faster, but currently there is no way to include hidden models for rendering with Octane.
Suv
[Req] Render hidden geometry
Max hasn´t different settings for viewport and rendering visibility?
face
face
http://vimeo.com/user2509578
What do you mean?face wrote:Max hasn´t different settings for viewport and rendering visibility?![]()
face
It's not object property, but it's a renderer feature. You can find it under Common render settings.
It's very easy to implement. Octane should just ignore the hidden status of an object and render it no matter what.
From Max docs:
Renders all geometric objects in the scene, even if they are hidden. Suv
yes it is very useful. if you set the object properties that are useful in two.
And yes, what about the proxy? (like vray proxy) or (proxy view like a "box"). will it be?
*Very bad English
*Very bad English
Core i5 76o @ 2.8o GHz | ZOTAC gtx58o AMP 1536Mb | MSI gtx46o 1o24Mb | Corsair ForceGT SSD12o | Gskill 16Gb RAM 16ooMHz
OctaneRender® for 3ds max®
I mean, in Softimage, i can hide an object for rendering, for the viewport or both. And there it is an object property.suvakas wrote: What do you mean?
Suv
I think in Max it is the same. You are right, it is also a renderer option under the common render setting, but only because the renderer ( in this case MentalRay ), searches each object to this property.
It is the same with moveable proxies. It is an object property but the renderer searches each object for this property.
A render property can be the renderer options which will have the parameters under it for the max samples or the kernel type.
I was only wondering because Max haven´t the different visibilities for rendering and the viewport...
face
Of course there is a "Renderable" object property in Max too, but it's irrelevant for this topic.
Basically I'd like to see this kind of logic implemented:
Suv
if (node->Renderable() && !node->IsNodeHidden() || RenderHidden == true){render node}
