enhance smoothness in Octane?
rappet
Thnx guys for your responds trying to help :-)
@Face (and other who like to try)..
the original SKP is attached..
@roeland
I checked the "use OBJ vertex normals if supplied" and it is enabled
@steveps3
I checked the smooth enable, but I don't dare to bet cos maybe I missed oa setting :roll:
@kavorka
I tried to check the model and could not see if the vertices are not welded together
the settings
the settings
candle-ori.zip
original skp dowloaded at
http://sketchup.google.com/3dwarehouse/details?mid=3e6473aeac7d240bcbdb36da0ec8fda6&prevstart=36
(588.37 KiB) Downloaded 252 times
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
matej
Have you tried importing the mesh with the "interpolate using smooth groups" option there?
Else, I would suggest to import the .obj in Blender, clean the mesh, enable smoothing and then use Blender exporter to export to Octane.
EDIT: typo
cgmo.net
remon_v
I opened it up in Modo, ran a mesh clean up and it had to weld a lot of vertices.
So that's probably the problem.
Win7 Pro x64, Phenon II 940, 8 GB, Geforce 470 - Modo, Zbrush
rappet
remon_v wrote:I opened it up in Modo, ran a mesh clean up and it had to weld a lot of vertices.
Cool. Good to know this kind of problem can be soled. Thanx for trying and letting know :P
Don't know anything about Modo btw and learning another software will make my brain explode :oops: :
matej wrote:Have you tried importing the mesh with the "interpolate using smooth groups" option there?
EDIT: typo
Yes i tried, did not help.
And yes, good suggestion, i'll try to find out if it is possible to clean mesh in c4d or in sketchup.
Thanx, I got homework to do and will get back when next wtep is made hopefully.
Otherwise I'll take a look at Blender, only learned about the existence a while ago.
Maybe I made the wrong choice buying c4d while ago, maybe not :?: I'll find out in time.
Greetz and tnx for info and suggestions
tuts3d
In sketchup, double click on the candle body or pick all the faces of the candle. Then right click and pick smooth surface. Increase value. This might help.
win 7 64 bit/ core i7 4770k/ 32 GB ram / gtx Titan sc/ asus Maximus vii hero MOBO
rappet
tuts3d wrote:In sketchup, double click on the candle body or pick all the faces of the candle. Then right click and pick smooth surface. Increase value. This might help.
Sadly not.. That was the first thing I tried before posting here.
Return to “Works In Progress”
