C4D could not launch Octane
Hi all, i keep getting this error rending when i render an animation from C4D R13 Studio, its renders only a few frames then this comes up every time
Nehale
Windows 10 x64 | 2x GTX680 | i7 990X | 24GB
Cinema 4D R17 Studio + 3Ds Max 2017
OctaneRender™ for Cinema 4D 3.01 + OctaneRender® for 3ds max® v3.14
Nehale
Does it launch Octane at all? What does the console Window say?nehale wrote:Hi all, i keep getting this error rending when i render an animation from C4D R13 Studio, its renders only a few frames then this comes up every time
Cheers,
Marcus
Yes it works fine when i do a still image, the issue only arises when i want to render an animationabstrax wrote:Does it launch Octane at all? What does the console Window say?nehale wrote:Hi all, i keep getting this error rending when i render an animation from C4D R13 Studio, its renders only a few frames then this comes up every time
Cheers,
Marcus
Nehale
Nehale
Does Octane launch or not? I.e. is the error message incorrect or does Octane actually not start? And again, what does the C4D console Window say?nehale wrote: Yes it works fine when i do a still image, the issue only arises when i want to render an animation
Did you have these issues before or are you a new user?
Cheers,
Marcus
abstrax wrote:Does Octane launch or not? I.e. is the error message incorrect or does Octane actually not start? And again, what does the C4D console Window say?nehale wrote: Yes it works fine when i do a still image, the issue only arises when i want to render an animation
Cheers,
Marcus
Yes Octane launches and renders when i hit the render animation button, but only for about 10 frames or so them it stops and gives this error,so i always have to continue where it stopped rendering.
i was experimenting on another windows 7 PC and it works fine so i assume that my windows 8 might be giving the issue.
The console window at the bottom doesn't display anything when this happens
Nehale
Nehale
The console Window I mean is under Script -> Console... Could you open it and post a screenshot?nehale wrote:Yes Octane launches and renders when i hit the render animation button, but only for about 10 frames or so them it stops and gives this error,so i always have to continue where it stopped rendering.
Marcus
I rendered again to try and get this message again but now it stopped i really dont know why.
Thank you anyways for you willingness to help.
Nehale
Nehale
