OctaneRender® for Poser beta - build 1.01c [OBSOLETE]
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Poser, build 1.01c, which is the test/development version of the plugin.
In the event that you have a support issue, pls provide the following information:
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version (ie. 300.00)
- Poser version (Poser -> Help -> About Poser) - list the build number (eg. 9.0.3.23000)
- Also have ready a copy of the octaneplugin.log file from your Poser temp direction (Poser -> Edit -> General Preferences -> Misc tab to find the temp directory)
Change Log from 1.00o to 1.01c
- Pls view the video at https://vimeo.com/54438243 for a demonstration of the features below
- Instancing is now supported. Select a prop or figure in the Material room and change it's type from "mesh" to "scatter". Then load or generate a transform. When generating a new transform file, mouse-over the input boxes to get a description of each field. It will help if you understand the Instancing concepts from Octane StandAlone.
- Refreshing the scene now leaves the material tree in it's previous state
- Middle mousebutton clicking the progressive save button opens the progressive save folder
- Progressive save filenames now have the time appended to the filename (in HH-MM-SS format)
- you can now minimise the settings and viewport windows. Once the viewport in minimised, the render will continue rendering (if it was not paused)
- Added OctaneDefaults for GLOSSY_SPECULAR, GLOSSY_ROUGHNESS, GLOSSY_BUMP_POWER, which are the defaults used for glossy materials converted from Poser materials. Set GLOSSY_DIFFUSE_RATIO to 0 to force all materials to be glossy (rather than materials with low specular in Poser being converted to diffuse). NOTE: These do not set the defaults when you change a material type from diffuse to glossy in the Material tab - in this case the Octane defaults are still used.
- Resizing the viewport no long refreshes the entire material and settings tree
- Picking a focus now no longer looses the tree state in the material tab
- Changing a glossy to specular material (or vise-versa) does NOT copy the roughness and index pins anymore (previously the glossy roughness was impacting the specular defaults)
- Where a Poser material has a texturemap and the diffuse_color/diffuse_value is not = 0/0/0 or 255/255/255, the texturemap will be multipled by the color in the Octane material
- Changing a texture environment to "daylight" will NOT now copy the power setting (since daylight should be the default setting of 1
- Reimport material/figure/prop/scene now context sensitive for the tree item you rightclick
- Remove bump maps now context sensitive for the tree item you rightclick
- New rightclick material option to save the material node to the Poser Material. This is saved in the Poser Material nodes, and used as the Poser to Octane conversion template when next converting that material. Save the prop/figure to the Poser library to save the Octane node setup. Do not edit the nodes in the Poser Material Room - and they are not supposed to be connected to the Poser Surface.
- Grouping props are now not imported into the Octane scene
If you have questions....
- Read the manual
- Read the FAQ
- Watch the Features Video
- Read the Features Blog Posting
- Watch the Introductory Tutorial
- Check the Facebook Page
- Post your question on this forum thread
Troubleshooting
- GUI issues (lock-up/crash) on large scenes (ie. 4million polys) - potentially due to the Windows Vista/7 "Timeout Detection and Recovery" http://msdn.microsoft.com/en-us/library ... 87368.aspx. Settings can be changed using Regedit. The recommended setting for Octane are registry setting HKLM\System\CurrentControlSet\Control\GraphicsDrivers, TdrLevel = 3, TdrDelay =10 (if these settings are not already there, rightclick the right panel -> New -> DWORD). You will need to reboot after changing these settings.
Known Issues with this Test Version
- There have been reports of Poser crashing when opening or resizing the Octane Render Viewport where the scene is using the majority of the graphics card memory. The next version of the Octane API has an addition memory function, which I hope will assist trapping this situation.
Limitations
- Loading a Poser scene by double-clicking a pz3 file in the Windows file explorer, or selecting from your "Recent Files" will not load the previously saved Octane scene data for that file when Poser starts. This is due to a Poser bug which has been reported to Smith Micro. Instead, use the Poser menu File -> Open to open any pz3 files which contain Octane scene data.
- Material Picking (by clicking on a material in the Poser Material Room) does not select that material in the OctaneRender material tab if you have a camera selected in the Parameter Dials window.
Download the plug HERE
Hope you enjoy using the plugin!
Michael314
wow! That's a really good new feature to store the Octane material settings in the Poser material. It will definitely be a big time saver.
I noticed you don't even need to save the full prop, it's also working with the mt5. So a single material definition can hold a Poser-optimized material and at the same time the Octane material.
Thanks a lot, it's working like a charm!
Best regards,
Michael
Win XP 64 | GTX 580 (3 GB) | Core2Quad 2.83GHz (Q9550) | 8GB
Win7 Ultimate 64 | GTX 680 (4 GB) | Core i7 X980 | 24GB
bjhaber
Hi. Got this message when trying to start renderer...octane plugin never opens.
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 8545, in ShowOctaneOptionsWindow
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 6111, in Init
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 7311, in refreshScene
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 7983, in copyMeshToOctane
WindowsError: exception: access violation reading 0x0000000000000060
Details:
Windows 7 64bit
memory 16gig
Card: GTX570 1280mb
nvidia driver: 9.18.13.697
Poser 2012 9.0.3.23027
Hi bjhaber
That should not happen! I suspect there is some geometry in the scene with is tripping up the load process.
Does it happen on the Poser startup scene (ie. Andy plus ground plane)?
Can you pls post here, or email [email protected] a copy of the octaneplugin.log file (see top of this thread to find it's location).
Quick update....
This version is not loading meshes subdivided with Snarly's script. This is fixed in the next version.
The next version also has Genesis (DSON Import) for Poser working!
p3taoctane
Thanks Paul
Ignore my DSON question in old beta forum
Will watch this one from now on
Peter
Zay
Was trying to do my first production renders with this plugin but totally forgot when you move the camera the scene will update. That's preventing me to keep on working in Poser while the viewport is minimized and rendering. Is it possible to add a button or something to lock the scene in the viewport so it can't get updated and you can keep on working in Poser?
Was also wondering if it is possible to add a batch render list for saved PZ3/PZZ files in the future?
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
Hi Zay
Yes to the first request - it's on the list.
The second request is doable, but a big job. I'll add it to the longer term wishlist.
A quick note to say the next version has some substantially improved error reporting. If there are any Octane or Cuda errors, these are picked up by the plugin, displayed to the user, and then the plugin gracefully closes, and a "cuda.log" file is written detailing the issue. This will hopefully pickup any mesh construction issues or out of memory errors before they manifest into a python exception or Poser crash. The viewport also has a low memory warning (if you go below 20Mb of video card memory free).
cuda error dlg.png (8.68 KiB) Viewed 8376 times
mlru
With the scatter type, is there a chance to replicate a mesh in a controlled way, like to arrange an object 4 times side by side in an even distance?
And - can figures be scattered as well as props?
Win11/64Bit | GTX 4090 24GB | NVidia Driver 546.29 | Octane 4.05 | DAZ Studio 4.21
Return to “Poser”
