hi enrico, maybe can you explain a little bit about work mesh light ? i mean, how use it ?
regards
Refracty wrote:great work - Did you try pmc / pt for comparsion?
merid888 wrote:thank you enrico you are friendly, i'll try to practice this step
is different put just an octanelight or is the same thing ? just i need put the glass window into octanelight ? or i'm wrong
regards
merid888 wrote:hi enrico, good morning from merida, i would know if you can support me, how values do you use when use the emiter light in the windows, i use power 100, efficency 0.015, samples 0.001 is correct ? or i'm wrong ?
hope you can help me
thank you
Return to M is for Metaverse Gallery
