Alpha Rest Room
enricocerica
I modelled some new furniture so here are some shots of a rest room with the theme based on text and numbers.
Edit :
Here are some tec info,
Render kernel : Ambient occlusion mode 4 (like brute force in VRay)
Lighting : HDR + mesh lights to increase light coming from windows
Material : 2 x GTX580 3GB
Rendering time : 2 - 3 hours in 1600 x 1600
Postpro : To fix lighting and remove some residual noise
Polys : About 8 million including instances (like for the carpet)
Sometimes I ask myself why I spend so much time on doing so many personal projects and sometimes I get encouraging answers.
My Alpha Rest Room has been published in the last november issue of 3D World magazine and this helps to proceed on working for nothing else than some satisfaction ;)
http://www.myline.be
RobSteady
Looks great! ;)
Rendertimes?
Elvissuperstar007
environment HDRS ?
dmcprince1
Looks impressive. Good job, as always :)
Win7 64bit | AMD FX 4100 @ 3.7 GHz | AMD Radeon HD 7700 Ghz Edition OC | 8GB DDR3 1600MHz RAM
evo
masterpiece!
Intel Core i7 920 @ 2.67GHz, 6.00 GB, 896 MBGeForce GTX 260 (x2), Windows
RIBS_stairs
http://www.refractivesoftware.com/forum ... =5&t=17973
FractalBuddha
Wow :)
Imagine reality
2 x GTX 560 | i7 | windows 7
evo
pmc? aproximatly time? gtx580x2?
RIBS_stairs
paoloverona
great renders Enrico!
I love your works...great illumination, great shading and textuing, great views, all at 100%
My preferred view is the one with the toy car. I havve some questions:
- in the first image the forniture on the left has a text-texture applied or just reflects the texture of the wall? (if the second option, isn't the shader too reflective for being a wood material?).
- the texture of the floor looks amazing, did you created it by yourself?, does it have a bump map? (seems not)
wait to see your next work ;)
Cheers, Paolo
intel i7 3820 3.6GHz, 16Gb 1600Hz, windows 7 professional 64bit, gtx 580 3Gb x2, Octane 3dsMax 2.58
gabrielefx
great renders!
special atmosphere...
that letters are the power bill?
User avatar (Default)
merid888
very realistis enrico, maybe you can share the lighting parameters ?
thank you this images
regards :)
