"warning render is failed" same problem here.
I can't render all night like before i do. it always stops in somewhere in the middle. i render animations. 3 GTX 680
OctaneRender® for 3ds max® v1.0 RC2[Test]
What image is what?
If you open octane viewport, how much gpu memory does it take and how much memory do you have?cancel wrote:"warning render is failed" same problem here.
when material editor is open, is very strong lag viweport
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
hi karba i have 24 gb ram bus 1866 ddr3, this is enough ?
my cards are gtx470 x 2 and they have1280 mb each one
In your memory stats it is 0.919/1.225Gbmerid888 wrote:hi karba i have 24 gb ram bus 1866 ddr3, this is enough ?
The rest of your memory is likelly taken by 3dsmax.
Do you have render fail warining when you try to increase render image size?
exactly when i increase the render image size appear warning render failed.
that is the problem karba
- truerender
Mesh is the same in all images.What image is what?
The question is, what octane does not perceive subtle geometry.
Scene send?
