OctaneRender® for 3ds max® v1.0 RC2[Test]
Karba
merid888 wrote:hi karba another bug of octanerender into 3ds max, now say warning renders is failed !
i attach image
i need close and restar again the octanerender viewport to load the complete scene
please, let me know why happen this
regards
Does it happens when render reaches max samples?
paoloverona
i attach image
regards
same problem for me, it happens occasionally, sometimes after just 2 minutes from, other times after 10 :?:
intel i7 3820 3.6GHz, 16Gb 1600Hz, windows 7 professional 64bit, gtx 580 3Gb x2, Octane 3dsMax 2.58
Karba
paoloverona wrote:
i attach image
regards
Does render just stop to render after this message?
paoloverona
Does it happens when render reaches max samples?[/quote]
same problem for me, it happens occasionally, sometimes after just 2 minutes from, other times after 10 :?:[/quote]
Does render just stop to render after this message?[/quote]
still testing in this moment: the alert "warning render is failed" pops up in a intermittent way (random duration) but the counters (sample/pix, sample/sec., time) still progress....seems that the render continue to being calculated
User avatar (Default)
merid888
for me happen when i do click change the size of image, height and with, i strecht the viewport to do more big and that moment appear the message, warning, then render stop, i have close the viewport and star again
another thing, the sun is so slowly when i use it, maybe is for the version ?
thank you for ask karba
mbetke
Getting desperate here with my instances.
As soon as I enable them it slaps the gras texture all over the place. Checked with Beta 303 and RC2. On Max2012 and Max2013.
Really annyoing. Lost whle evening fiddling around with the stuff....What do I wrong?
Around 55.000 instances à 70k tris. Is there a limit somehow?
White trees and bushes are missing textures (not Octane fault).
Funniest thing I used the same gras with even more instances but other scene two days ago and it used to work.
PURE3D Visualisierungen
Karba
mbetke wrote:Getting desperate here with my instances.
Can I have your scene?
Karba
merid888 wrote:for me happen when i do click change the size of image, height and with, i strecht the viewport to do more big and that moment appear the message, warning, then render stop, i have close the viewport and star again
Was this bug in older versions, 3.03?
merid888
hi karba, is it OctaneRender® for 3ds max® v1.0 RC2[Test] the bug
thank you
Karba
merid888 wrote:hi karba, is it OctaneRender® for 3ds max® v1.0 RC2[Test] the bug
thank you
Do you have enough GPU memory?
Return to “Autodesk 3Ds Max”
