how did you do it? I do not worksuvakas wrote:Nice!
Thank you for the Phase function.
Suv
[edit]
30 min render of a light beam
OctaneRender® for 3ds max® v1.0 RC2[Test]
- Elvissuperstar007
- Contact:
win 7 /64x C2Quad 6600 2.4/ Nvidia 9800 GX2 1gb 512 bit + Asus 480 GTX/ DDR2 8Gb / NVIDIA 460 GTX 2GB/2x NVIDIA 580 GTX 3GB
Do you use glossy material for the walls?boris wrote:different test results here. maybe because of direct light kernel.
made a short test in preparation to an animation. same scene same settings. direct light kernel with AO. hotpixels?
second question: direct light kernel is the way to go for an interior animation like this NOT concerning buying another 10 gpus?
Please show your comparative renders. I am sure, they are not the same.Elvissuperstar007 wrote:Standalone RC2 win 7 64x
GTX Palit 460 2Gb
336 Cuda Cores
0.57 семплов
4 . 30
GTX 580 3gb
512 Cuda Cores
1.07 семплов
2 . 27
GTX580 3 gb + 460 GTX 2 gb
848 Cuda Cores
1.64 семплов
1 . 38
GTX Palit 460 2Gb
336 Cuda Cores
0.48 семплов
5 . 26
GTX 580 3gb
512 Cuda Cores
0.89 семплов
3 . 04
848 Cuda Cores
1.39 семплов
2 . 00
Did you use multisub object materials for the bushes?Plankosmos wrote:Hey Karba.
First thax for the update. Here first test results:
The export of instances objects is now much much faster again.![]()
The texture count works now.![]()
But I also came across some old/new problems:
As u can see in the second attached picture below (with the building), there are some texture issues. Thanks to the texture count I can now say, that they are not due to the texture limit. Some shrubs miss textures completely and appear in white or other colors.
I then created a completely new scene to test the shrubs again. There I had the problem that the ground plane didnt appear in the viewport, so that it seems as if the shrubs were placed in the air first attached picture). As soon as I switch off the shrubs (they are instances and octane proxies), the ground plane appears in the viewport - and the other way around.
Greetings
Do you use your gtx 580 for display?mykola1985 wrote:I think i have a strange problem:
my gtx 580 has 1,470 mb of memory, but
as soon as I reach 1000 mb limit. octane won't render anymore showing
the following in the render screen:
WARNING RENDER IS FAILED!
what is that?
- freelancah
Windows 7 64bitKarba wrote:Do you use windows XP?freelancah wrote:I was able to replicate the issue that I described to you before. Here's a screenshot
