OctaneRender™ Standalone v1.0 RC 1 [obsolete]
Jaberwocky
Actually the way they implement Texture mapping in Sketchup would be pretty Cool in the Octane Stand alone.If you don't use Sketchup then watch the link..
http://www.youtube.com/watch?v=p6SOahO6LDk
indexofrefraction
can you please be a bit more consistent with the version numbering ?
OctaneRender 1.025 beta 2.58e
OctaneRender 1.025 beta 2.59 -> 2 versions in 1 filename?
octane_beta_303.app -> 1.? beta 3.03?
octane.app -> 1.0 RC1 -> 1.0 newer than 1.025? :D
i get it of course, but it is confusing .)
btw : 1.0 RC1 updated?
is this a 2nd 1.0 RC1 with the same name?
Mac Pro (2012) 2x6 Core | 24GB | 1 x Geforce GTX580/3GB
abstrax
indexofrefraction wrote:can you please be a bit more consistent with the version numbering ?
Yes, but that's not our fault ;) There will be only 1.0 RC<x> with <x> being (hopefully) a one-digit number, then there will be 1.0 and then we continue with 1.01, 1.02 and so on. It's not completely decided yet, but that would probably make the most sense. We will also release stable versions and test releases. The version number will not indicate stable/test releases, but the release notes will.
In a nutshell: With 1.0 there will be a cut in the version number scheme and sanity will come back.
I hope that makes sense,
Marcus
Seekerfinder
abstrax wrote:
Seekerfinder wrote:
abstrax wrote:.
That does not mean, that we will drop everything, go to the Bahamas and take a holiday for the next 10 years :)
Marcus,
First, well done to team Otoy (though I would feel a bit odd having lost the best 'beta' software on the planet with V1 & all)
Second, any chance you guys could tick that 'ol SHADOW CATCHER todo off the list before you head for the Bahamas?
Seeker
Yes, we will tick that off, before we head to the Bahamas, but not before we releases 1.0 ;)
It's on our to-do list like lots of other things.
Cheers,
Marcus
Gutted...
Also wondering if a Revit plugin is on the agenda at all?
Seeker
abstrax
indexofrefraction wrote:btw : 1.0 RC1 updated?
No, it's the same Octane. There just has been a quick fix for the bug where the wrong CUDA code is used for GPUs with compute model 1.1, 1.2 and 1.3 (as stated in the updated release notes). Since this problem affects only a small group of users it didn't make sense to do a new release.
Cheers,
Marcus
Elvissuperstar007
https://vimeo.com/52170540
I can not move the ball
abstrax
Elvissuperstar007 wrote:https://vimeo.com/52170540
You were running out of graphics memory:
Elvissuperstar007
it is not possible! ball with a single texture 1200x1200 Jpeg could not load 2GB of memory
Karba
Do you use any other applications consuming gpu memory?
Elvissuperstar007
no
( я создавал новые материалы в онлайн библиотеу, загрузил штук 4, после отлучился на минуту, когда решил покрутить болванку.. появилась эта надпись красная на панельке октана Оо и зафризило вьюпорт)
