ciao beppe
Placement Node BIG problem for me
you can export single elements positioned at the origin from rhino and use 3ds max with simple cubes just to get the scatter matrix
ciao beppe
ciao beppe
yeah I think it's more easy then the grasshopper thing....bepeg4d wrote:you can export single elements positioned at the origin from rhino and use 3ds max with simple cubes just to get the scatter matrix
ciao beppe
Only the problem is I am not a 3dsmax type , I like to do scene setup in Rhino 5 which is the fastest workflow for me !! I think I will end up go back with the method of putting 2 placement nodes for 1 instance... thanks for your reply !!
see my definition of grasshopper in "rhinoceros plugin" thread...is simple to obtain a matrix for the istance!
http://render.otoy.com/forum/viewtopic.php?f=41&t=23430
SORRY, MY ENGLISH IS BAD!
2 Xeon quad core E5440_8gb Ram_Nvidia GeForce 2GTX 780ti 3Gb/Nvidia Quadro K2000_Win10 64bit_Octane 3.02_Rhinoceros3D
Thanks Daniel79Daniel79 wrote:see my definition of grasshopper in "rhinoceros plugin" thread...is simple to obtain a matrix for the istance!
The point of this thread is I have many mesh that need to be instance in different scene.
There are not 20 instances of one single mesh in a scene...
There are 20 DIFFERENT meshes need to be instance in order to move freely in the scene and re-use them in another scene...
So in this case I will need 20 scatter nodes, right ?... If every time I do re-position them by switching between host application and Octane just for update the transformation matrix then I think we use the scatter node in the wrong way...
And if I go back to use the placement node, I will need 2 placement nodes for one instance but this way is better then the scatter node...
That is something I feel uncomfortable about how Octane dealing with the transformation for placement node...
Thanks for you reply...
Unfortunately just because a feature doesn't work how YOU want it to work is not a reason to change it. The way that the placement node works is completely logical. It is just the way that you use them that needs to change.
(OS) Windows 7(64)
(OS) Windows 7(64)
I solved these problems - placement and scatter -with the huge help of TIG.
Here is the plugin for Sketchup how to export scatter data for components/instances. Read all of the topic (46 posts)
http://render.otoy.com/forum/viewtopic.php?f=31&t=22581
- Michael314
I was also very confused with the placement node, in my case with scale and translate. I translated the object, then scaled it, and the translation was scaled as well.
It is just a definition of sequence, but to me, it would also be more logical to first translate, then scale.
It's a matter of taste, I guess. But if many users are confused, there would be a chance to swap the order before 1.0 is released.
Best regards,
Michael
Best regards,
Michael
Win XP 64 | GTX 580 (3 GB) | Core2Quad 2.83GHz (Q9550) | 8GB
Win7 Ultimate 64 | GTX 680 (4 GB) | Core i7 X980 | 24GB
Michael314 wrote:Hi,
Best regards,
Michael
YES... my topic is really talking about this
We have a PLACEMENT NODE that include all the necessary parameter for object translation + scale + rotation thats good, BUT in the real life when we want to move + rotate + scale object in OCTANE it is totally impossible to figure out HOW to put every parameter in a SINGLE NODE....
now I just use two placement node for place and rotate object in the scene.... not bad but it's not logical for me...
