Problem in exporting to animation.
kaskudo
guys,
I bought the octane yesterday and am having trouble to render a simple animation.
Appears the following error message ..Image
I do not know what else to do ..
Could you help me?
kavorka
unfortunately, you cannot use spaces in the exporter. Get a filename with no spaces and you will be okay. The exporter was originally made when Octane didnt allow spaces, so thats why its there, just hasnt been updated yet.
DayVids
You may find this helpful, I was experiencing some problems as well, and managed to get them resolved.
http://render.otoy.com/forum/viewtopic. ... 1&start=10
Also, if you're doing an animation there is a line you need to change in the 1.20 exporter.
http://render.otoy.com/forum/viewtopic.php?f=32&t=23546
Hope this helps with your problem...
CPU - i7-950 3.06 Ghz, 24GB Ram, Win7 x64, 2 display monitors, GeForce GTX 580 3GB Classified. I'm glad to say I LOVE OCTANE!
kaskudo
Thank you.
I will read this information and test again here to export my animation.
After I explain here if it worked or not.
kaskudo
Guys.
I have no spaces in the path that I put in my project, I have strange symbols in my project and yet does not work nor the export of an animation.
I'm using the plugin .. 1:19
Is there a more updated?
I'm using Blender 2.63 (r46461: 46487M)
I would like a solution and can not do anything, I need to surrender much of a job.
DayVids
Can you copy and paste the blender info panel from when you have the error?
Also, 1.20 is found here-http://www.refractivesoftware.com/forum ... 373#p96373, but remember that there is a change to the script that you have to do, per my threads I pointed you to.
PM me if you have no additional luck.
What does the python drive info show for your location that you're saving to?
Dave
kaskudo
Here is my problem.
Traceback (most recent call last):
File "C:\Program Files\Blender Foundation\Blender\2.64\scripts\addons\octanerender\engine.py", line 65, in render
error('Image output directory is invalid or contains spaces "%s" ("%s")' % (octane_render.path,animPath))
File "C:\Program Files\Blender Foundation\Blender\2.64\scripts\addons\octanerender\utils.py", line 81, in error
raise Exception("Octane plug-in: "+error)
Exception: Octane plug-in: Image output directory is invalid or contains spaces "C:\Users\Douglas\Desktop\OCTANE_RENDER\" ("C:\Program Files\Blender Foundation\Blender")
Thanks..
orion_uk
I just kept getting this..
I changed my render/image output directory to C:\RENDERS
Saved my Blender scene, quit Blender and re-started Blender and its running fine now :)
Well, kind of!
Render animation renders the first frame fine. I click render animation, Octane starts up, renders first frame,closes but does NOT start up again for the second frame!
http://www.Neil-Isted.com
Intel i7 870/2.93 GHz
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
OctaneRender™ for Blender
Ds pro
OR Standalone V4
Poser Plugin
orion_uk
Never mind, matej showed me a solution...thanks matej ;)
This URL here
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
lakris
Im having the same problem(mine says line 65), and none of the above links/help is working :|
I hope the Blender official plugin is coming soon.
Win 10 - 64 bit, Intel Corei7-7800X CPU @ 3.50GHZ, 32 gb ram, 2x Gigabyte RTX 2060 SUPER 8GB, OctaneRender for Blender - The most recent stable build - Houdini indie 18.5.499
Return to “Blender”
