OctaneRender™ Standalone v1.0 beta3.01 [obsolete]
PeterCGS
roeland wrote:I have added a Kepler build for the new GTX6x0 cards to the original post.
Roeland
Thanx Roeland! Will test it ASAP! :)
Win7, i7 980 Hexacore, 24GB RAM, 3xEVGA SC 670 GTX 4GB
PeterCGS
Wohoo no more crashes when closing down using 3xGTX670! :) And a couple of percent faster than 2.58E (maybe like 0.5% or something.. )
Thanx for the update!
Elvissuperstar007
Tests 600 vs 500 post results
vladislav
Win 7 x64
Core I7 3930K 4Hz
GTX 660 2GB x2
GTX 630 4Gb
3d Max 2014
boeing727223
Great update, just not yet clear on export out of DAZ. I was originally exporting out of DS at 1% custom and setting the obj import into Octane as meters. I now tried exporting out of DS at the DAZ export setting of 100% and import using the obj DAZ setting....figure is of course much bigger. I tried setting the DS export at 1% and choosing the DAZ import obj setting in octane and figure was just a bit bigger than the original settings I was using...1% export out of DS and meters obj setting for Octane.
Any DAZ folks can confirm the new export setting out of DS? Should it be 1% export still or the DS export of 100%?
Tugpsx
boeing727223 wrote:Great update, just not yet clear on export out of DAZ. I was originally exporting out of DS at 1% custom and setting the obj import into Octane as meters. I now tried exporting out of DS at the DAZ export setting of 100% and import using the obj DAZ setting....figure is of course much bigger. I tried setting the DS export at 1% and choosing the DAZ import obj setting in octane and figure was just a bit bigger than the original settings I was using...1% export out of DS and meters obj setting for Octane.
Using either method produces acceptable output however here are the results with Octane set to Daz Scale.
First one was exported using D2O with scale set to 10 percent
Exported from D2O set to 10 percent
The second using daz export option at 100 percent
Using DS export at 100 percent
first one easier to manuver the camera than the second where as you will have to press shift to speedup your mouse movement, since it produces a much larger scale scene.
Note how large the scene is in comparison
boeing727223
Thanks, here is a WIP exported from DS4.5 at 1% and imported into 3.01 using the obj DAZ option....camera was easy to use so this might work.
Tugpsx
boeing727223 wrote:Thanks, here is a WIP exported from DS4.5 at 1% and imported into 3.01 using the obj DAZ option....camera was easy to use so this might work.
Correct, the scene is definately larger, but in order to get the camera at the correct position you had to move it into place using the shift key. In the case of an animation this could/would be a nightmare. The current D2O option does allow you to scale the export from 1 - 100 percent. Will have to try a simple animation using the new octane setting and export at 100 percent to see what effect it will have with the exporter.
For instance in the scene posted above the cameras are loaded at the default positions as exported. Notice that in the daz export you are under the building and can see the corner block whereas the D2O you are inplace where the camera was in the scene. D2O has the advantage that it calculates where the camera should be loaded whereas the default export does not take into consideration the camera location.
t_3
by the way, i have good reason to believe ;) that the daz native unit is centimeter, so imo there doesn't need to be any "native" unit at all, since the .obj import dialog already handled centimeter-based meshes (whole different story with poser though)...
boeing727223
Great info folks!
