OctaneRender™ Standalone v1.0 beta3.01 [obsolete]
roeland
The OctaneRender™ Team is proud to announce the test release of OctaneRender™ beta 3.01.
This release fixes a lot of bugs found in the first instancing release.
Changes since beta 3.00
Lighting
  • Fixed bugs in direct ligting when using instanced emitters causing incorrect or missing illumination.
  • Direct light from a textured emitter is rendered correctly.
  • IES lights on instances are oriented correctly.
Geometry
  • Mesh files and CSV files in scatter nodes can be reloaded.
  • Scatter nodes using a CSV file load and save correctly, and CSV files containing multiple spaces between values are parsed correctly.
  • Fixed GPU crash when selecting a geometry node that doesn't render any objects.
  • Shading normals mode of the deep_channel_kernel works correctly again.
Other
  • Fixed quick previews of procedurals.
  • The noise on renders with a low amount of samples per pixel is different for each render, removing the effect of having a noise overlay in animations, but introducing more flicker.
  • Linux users can use the numpad enter key.
  • The speed of moving the camera sideways is adapted to the field of view.
  • Added Daz and Poser native units in the OBJ file import preferences.
  • Don't allow creating loops in the node graph and causing a crash.
  • Fixed memory leak on opening a new scene.
  • Fix crash when falloff node gets its input through a macro input pin.
Download here:
Windows:
ZIP archives:
- 64-bit32-bit
MacOS X:
- 32-bit and 64-bit
Linux:
- 64-bit
Driver Requirements: This release was built with CUDA 4.0(http://www.nvidia.com/page/drivers.html).
For Linux and Mac OS you also need to install the CUDA Toolkit 4.0 (http://developer.nvidia.com/cuda-toolkit-40).
For Mac OS you also need the latest CUDA 4.0 driver (http://www.nvidia.com/object/mac-driver-archive.html).
These builds support only Tesla and Fermi cards (compute model 1.0 to 2.1).
Kepler GPUs are not supported at the moment but a fully functional build is being developed.
Kepler build:
This build will run on Fermi and Kepler cards.
- Windows 64-bit
Most recent documentation: 2.58e user manual
Yours,
The OctaneRender™ Team.
Synthercat
10% slower in Specular Material Preview (compared to 1.0 2.59) but I guess you know that!
Thank you for your work... I must try to learn about instancing now :roll:
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
thanks roeland, i'm testing right now ;)
[*]Linux users can use the numpad enter key.
in the next release is possible to have this feature also for osx?
abstrax
bepeg4d wrote:thanks roeland, i'm testing right now ;)
We didn't realize that it's a problem with Mac OS, too. We will look into it.
Marcus
thanks marcus, anyway this osx version seems extremely more stable and it's a pleasure to have the emitters back ;)
big thanks to all the team :D
steveps3
Sounds like a great update. My current scene has 5 CSV scatter files and having to update each of these every time that I made a change was a pain. I will try it out tonight.
(OS) Windows 7(64)
Refracty
great update. so i guess that maya users will benefit of the new sdk soon. time to instance directly inside maya :)
sdwhitton
great! Is there a corresponding new MaxScript exporter thingy to go with this, or do I have to upgrade to the full blown plugin for Max?
workstation well past its sell-by-date, Vista 64 bit (!) with a pitiful amount of RAM, re-invigorated with a GX 590
3ds Max Design 2011 (have 2013 but can't be bothered to re-do all the UI), CS5, and that free z-brush program, whatever it's called
smicha
Good news. Thanks.
AndreaMannori
It's beautiful to come back from holidays and to hear about a new release!
Andrea Mannori
win 8.1 x64; nvidia 770M driver 340.52; octane standalone 2 + c4doctane 2.
