OctaneRender® for 3ds max® v1.0 beta 3.00d[Test]
- MaTtY631990
Good release
. I have come across a bug with blackbody/texture emission materials. There is light emitting from the materials but there is no self illumination visible on the mesh itself.
Hi Karba
New release ! great.
I have a personnal request, that may interest other user.
I'm used to test textures while rendering with octane, but I have to stop and restart OctaneRender viewport in order to take in account the new texture (I mean a texture that was already in memory and that has been changed and resaved with the same name).
Is it possible that in a nxt release, such a change will be taken in account automatiquely as 3dsmax does.
Thanks in advance.
Thanks in advance.
I don't think it is possible as long as 3dsmax plugin use only texture path to track scene changes. If this path is the same it is impossible to detect the change.bicket wrote:Hi Karba
Thanks in advance.
Thanks for your answer karba.
- MaTtY631990
This release seems to render slower on final output compared to recent release of 3.01 standalone release. Even with a simple plane and teapot. The plugin renders for 19 seconds at 640 x 480.The kernel used is pathtracing and lighting done with daylight system. The 3.01 standalone release however renders this scene for 11 seconds. I can't understand why the plugin looks vastly different from the standalone release in the case of materials and settings.
Karba wrote:I don't think it is possible as long as 3dsmax plugin use only texture path to track scene changes. If this path is the same it is impossible to detect the change.bicket wrote:Hi Karba
Thanks in advance.
I karba,
Isn't it possible to add an update button on the texture parameter panel ?
- update button.jpg (52.01 KiB) Viewed 4620 times
merid888
Is this bug only in my case?
When I am using HDRI environment octane viewport display nothing (checker all over the octane realtime window), or just simply black.
If I am turning using hdri off - everything fine, when octane viewport already opened and rendering scene without hdri environment - it ok and I can even turn it on and it works. But I can`t render when hdri on at the very beginning. Sorry if all of this text is confusing
asus p8b ws [email protected] RAM-16gb and 3xGTX580 3gb I love octane and you guyz doing amazing job for us, THANK YOU
- gabrielefx
install the latest nvidia drivers, 306 beta for example
Hi Karba
I think i found a bug..regarding splines, they are not renderable unless i put and edit mesh or edit poly mod on top. can Anybody confirm this please?
Nildo
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
