Sunlight through a glass
Karba
It looks like there is a possibility to make algorithm for sunlight caustic.
We will work on it.
matej
Very nice. But if I may go slightly off-topic - probably the most asked feature regarding the sunlight system is to be able to use it together with a HDRI. Or, if not for illumination, at least being able to use the HDRI for reflections, because sunlight produces completely uniform & dull reflections... Just something to keep in mind if you are doing research with sunlight.
cgmo.net
Basselito
Nice to see Karba!
gabrielefx
architectural glass?
I want it.
thanks
Refracty
Karba, that sounds perfect.
Best news since the DL improvements made by abstrax.
This feature and a shadow catching material along object motion blur and Octane is ready for any production.
abstrax
bepeg4d wrote::o super promising
it's PT or PMC?
ciao beppe
I think that was path tracing. This was a little trial of Andrey. It's not architectural glass, but although he is cheating a bit it looked quite good. We'll see if his approach is robust enough for you guys ;) (I surely hope it is)
Cheers,
Marcus
Refracty
if there comes at least a ray of sunlight throught specular material it will be a big step. good job andrey
Refracty
Karba wrote:It looks like there is a possibility to make algorithm for sunlight caustic.
We will work on it.
What is the progress on this topic?
Is this a feature that is to be expected in the upcoming releases?
Thanks for the update
suvakas
Isn't it the caustics blur parameter ?
Suv
