decimals issue
gueoct
I am applying roughness to a specular material to make it frosted glass.
At Roughness 0,000 it´s clear
Roughness 0,000
Roughness 0,000
With one click it´s Roughness 0,001 and VERY rough
Roughness 0,001
Roughness 0,001
To achieve a slight roughness have to change my spinner decimals to 4 or even 5.
Roughness 0,0001
Roughness 0,0001
Is there a way to work with reasonable units?
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
Karba
gueoct wrote: Is there a way to work with reasonable units?
There is not another way, sorry.
gueoct
i wish octane units would, like max units, range from 0 to 100.
in octane units 1,0 is the highest value
it´s much quicker to deal with numbers above zero without comma... :-(
petergazo
+1
I would prefer linear system where 0 is none and 1 is 100% - like in iray. Its so much easier to tweak parameters.
out of curiosty, can i ask why?
i5-2500k | 16GB ram | gtx460 2GB (display) + GTX580 1.5GB | Win7 pro x64 | v1.0 beta 3.00b | http://www.behance.net/petergazo
Proupin
why can't you just map the roughness value to another arbitrary scale, like 1-100 or from 0 to 1, in a way that is useful??? (wouldn't this be similar to a gamma transformation?) right now, not only it's hard to really use roughness directly, but mapping roughness and other logarithmic parameters (parabolic, exponential, whatever the case) with a bitmap is useless as well...
Win 7 64bits / Intel i5 750 @ 2.67Ghz / Geforce GTX 470 / 8GB Ram / 3DS Max 2012 64bits
http://proupinworks.blogspot.com/
gueoct
when workling with centimeters or even meters, having decimals set to 0,0001 is super un-handy.
Is is not possible to have custom octane units?
Return to “Autodesk 3Ds Max”
