Version 4.0-RC7-R4 (obsolete release candidate) 10.11.2018
Cheiser
bepeg4d wrote:Hi,
it seems that you have only ~4.5GB of VRAM available, so at least you can load less than ~20M polys, try to use Out-of-core geometry, if you have enough RAM.
ciao Beppe
Heh....i'm already using Out of Core. It says ~2gb is Out of Core.
I have 40gb ram
metaphysique
stefano-dear wrote:
aoktar wrote:
stefano-dear wrote: I also found this problem with network rendering:
Launching net render slave (4000017) with master 10...
unpacked file image has unexpected type
didn't receive all required images from master
invalid message received from network connection
slave crashed or was stopped via CTRL-C
reached the maximum number of consecutive runs of a slave (5) -> bailing out
Anyone respond about this, I'm having the same issue on one of my boxes.
artdude12
I'm getting an error message that says this version is no longer supported and cannot be activated.
4.05 Stand Alone is running with no errors. What is the problem with the plugin?
i7 4930K_Asus_RampageIV-Extreme_64GB_3-Titan_NVIDIA-337.88_Win7-64
artdude12 wrote:I'm getting an error message that says this version is no longer supported and cannot be activated.
Don't you see the warning about "Scheduled maintenance on OTOY"? Probably it's that.
artdude12
Ah, OK. I missed that. Thanks for the info.
imago10
Small question it's possible to run it with Cinema 4D S24? Or any Octane v4?
