@andrey.krivulya
Hi andrey.krivulya,
developers are fixing the issue and I testing it.
OctaneRender® for 3ds max® v3.06.4 - 4.39 [OBSOLETE]
- paride4331
merid888
- paride4331
Hi merid888,
did you try using scanline renderer mode, does your issue still happen?
You are not using a camera and only a Top down view. This can happen. Sometimes if you zoom to much in, the scene diappears. Its a 3dsmax issue I think.
Try to set up a camera and render again. Then it should work.
PURE3D Visualisierungen
i posted this problem 4 months ago when you using middle scroll to zoom in/out octane would just flip a viewport. It is still not fixed. It happens a lot when you work with large scenes . Version 2 never had this problem started with version 3merid888 wrote:GOOD AFTERNOON
I HAVE A PROBLEM WHEN I USE OCTANERENDER 3.06.04-4.39, THE VIEWPORT IS LIKE A MIRROR, I DON'T KNOW WHY HAPPEN THIS
SOMEONE CAN HELP ME ?
THANK YOU
ADD IMAGE
- andrey.krivulya
- Contact:
Wow! Wow! Wow! Awesome! Thank you very much!!!!paride4331 wrote:@andrey.krivulya
Hi andrey.krivulya,
Windows 11 Pro / Intel Core Ultra 9 285HX / 96GB DDR5 / RTX 5090 Laptop 24GB / 4TB SSD / MSI Titan 18 HX AI
My youtube channel with 3d tutorials ----- >>>> https://www.youtube.com/c/AndrewKrivulya
Hi It seems that if Disable PFlow instances is unchecked there are no pflow particles in octane viewport unless viewport % is set to something. Also particle brightness gets out of control.
when leaving a checkmark evaluation times is very slow but quantity multiplier viewport % can be left at 0 and brightness works ok.
so there is a big problem for us we have both pflow fire works and phoenix fire.
with Disable pflow mesh instances checked: PFlow is slow to load
with Disable pflow mesh instances UNchecked: phoenix fd evaluate 5-10 times slower
hopefully otoy can fix all this
the movement of the cube and the camera - they have one speed .... the question is what would it take what would the cube had blur
- motion kub camera.zip
- (30.4 KiB) Downloaded 296 times
- paride4331
Hi Goldisart,
you should activate movable proxy and MB in Octane property.
attached correct scene.
- motion_camera.zip
- (42.64 KiB) Downloaded 307 times
