Serious errors when using Octane C4D
lideborg
bepeg4d wrote:hi,
unfortunately the video does not give to much info :roll:
try with this link:
https://www.techpowerup.com/gpuz/
I know but it was more just to give a small appreciation of when it happened. That is in total random.
Anyway here is from today. Was sitting working in C4D/Octane for an hour or so, nothing fancy just shading and lighting. Rendered out the image and about 2 minutes after while just sitting in After Effects it crashed again, screen freezes and I get all these glitch-artifacts. When I reboot my computer it's total chaos, as seen in images attached further down. So double reboot makes it go back to normal again.
http://d.pr/i/WJEo[b] (Octane settings)[/b]
https://d.pr/Fe9a While not having anyhting open (Idle)
https://d.pr/dPP6 Rendering in LiveViewer
https://d.pr/ooaI Rendering to Picture Viewer
Here are some pictures from when it crashed, the glitch-artifacts on the screen and the first reboot.
https://d.pr/LuY0 (GPU-Z while screen froze)
https://d.pr/Vdjd https://d.pr/9pVk (Glitch)
lideborg
Back again here as the problems still occur. Feels like I've been trying everything now but just trying to get this fixed as it just makes my computer totally useless.
Some new problems are starting now, i get total freezes instead after the live viewer says "Render failure detected" The live viewer freezes up and a few seconds later the whole computer freezes. Tried to get as much info here as possible. Is there anything you might need to show if there is something else weird happening with the computer let me know and I'll try provide it.
http://d.pr/i/oohD (All my render settings inside C4D/Octane)
http://d.pr/i/T9kz (iPhone snap of GPUZ/CPU/log after computer froze)
Even manage during the few seconds when octane had crashed and before it froze to save out the log, attached below. And if you can't look at the images through droplr of some reason, let me know and I'll upload them somewhere else.
Thank you
Started logging on 03.01.17 16:50:25
OctaneRender 3.04.5 (3040500)
Scene created in plugin version -1
--------------------------- EXPORT LOG ---------------------------
Export materials time= 8.321 ms
Collect objects time= 20.275 ms
Mesh creation time = 50.401 ms.
Triangles:0  Disp.triangles:0  Hairs:0  Meshes:0
VRAM used/free/max:0Kb/0Kb/0Kb
Out-of-core used:0Kb  total used RAM:6.071Gb
Total export Time = 91.732 ms
Export materials time= 3.264 ms
Collect objects time= 6.918 ms
Mesh creation time = 22.19 ms.
VRAM used/free/max:2Kb/9.945Gb/12Gb
Out-of-core used:0Kb  total used RAM:6.201Gb
Total export Time = 44.466 ms
plugin already locked the result before!
CUDA error 719 on device 0: unspecified launch failure
CUDA error 719 on device 1: unspecified launch failure
  -> failed to copy memory to device.
device 0: failed to upload data texture 4 of context 0
  -> failed to deallocate device memory
  -> kernel execution failed(report)
  -> could not get memory info
device 0: detected an error on render device! trying to recover...
  -> failed to launch kernel(ptBrdf2)
device 1: path tracing kernel failed
device 1: detected an error on render device! trying to recover...
  -> failed to deallocate pinned memory
  -> failed to unregister pinned memory
  -> failed to unload module
  -> failed to bind device to current thread
device 0: failed to initialize resources
device 0: failed to recover - giving up and switching device to failed
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
Triangles:94k  Disp.triangles:0  Hairs:0  Meshes:1k
Device:0 TotMem:12Gb rtData:0Kb film:0Kb geo:0Kb node:0Kb tex:0Kb unavailable:2.573Gb temperature:84
Device:1 TotMem:12Gb rtData:0Kb film:0Kb geo:0Kb node:0Kb tex:0Kb unavailable:2.47Gb temperature:83
device 1: failed to initialize resources
device 1: failed to recover - giving up and switching device to failed
device 1: data texture 4 was not initialized
What's max temperature on gpus? It may be related with this.
lideborg
I never really seen them go above 83-84 but usually when rendering they are around 80.
I'm actually not a PC builder so I had a company set it all up for me, just ordered the parts. Although it's not always that it freezes when they are at full capacity, sometimes it's a minute after the render is done. But I can snap a shot of the setup later today and you might be able to tell if they get too heated bc of position
lideborg
As said I did not build this rig myself. Think maybe there is a chance I can put the lower card one more step down but not sure if it will make any difference? Anyhow here is some images of the build
http://d.pr/i/wK0v
http://d.pr/i/jL9G
http://d.pr/i/d806
atome451
Hi lideborg,
This may be a silly idea but I had a long time ago an unstable computer problem like this. It ended with a grilled PSU because I did not find the answer soon enough. In my case, it was a problem of defective lightning protection. I wonder if the instability of your computer corresponds with a change in its connection to the electrical network? Another power strip, another plug, a change of desk, ... As I had also brought my computer to a repairman who had told me that everything was fine, I wonder if this is not a track to explore in your case.
I hope this info will help you. I know how confusing it can be.
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
lideborg
atome451 wrote:Hi lideborg,
Tried bringing it around the office trying all these different outlets, but had the same problem.
Actually do you guys think it might be overheating? Is 83-84 degrees way too much? Should I maybe look into getting watercooling for my rig?
Decrease your frequency for testing them. Also try to disable some gpus for testing.
lideborg
aoktar wrote:Decrease your frequency for testing them. Also try to disable some gpus for testing.
Sorry for not understanding but how do i decrease the frequency? Also I've tried disabling one or the other but this still happening. I'll try it again though!
From some software nvidia or msi backburner etc.. Octane can't do anything if your gpus fails while compute.
