Displacement in UE4
Moderator: ChrisHekman
- DragonMotion
Hello! How do I use Displacement in ue4? I found this guide (https://www.youtube.com/watch?v=D-hM0hPOzz0), but I don't have the "Convert Displacement" option in the plugin setup. And connecting the displacement texture in octane instance does not give results....
- DragonMotion
I have the latest version. Downloaded the official plugin with the update from 2019-09-26. In UE4, I have the 0.24 BETA version of the plugin.EvolverInteractive wrote:Update your version of Octane.
- ChrisHekman
Displacement is partially supported, and subject to limitations. Because of this it is optional. You can turn it on in the plugin settings:
If you cant find this setting, upgrade to the latest version:
viewtopic.php?f=132&t=73883
- EvolverInteractive
You guys know just because it doesn't automatically do the displacement for you that, you can still adjust it in the Octane Material. To do a fresh install of the plugin, best practice is to delete, octane plugin in the the Unreal engine folder under plugins, launch unreal without it, reinstall, and you'll be good.
